quality problems and thinking about re- editing and re-upload
  • July 31, 2024
  • 1281 views
Hi there!
I just started out and one of my uploaded photos (a pano) got rejected due to quality problems. I actually over- sharpened it, as I initially edited it for printing. Now I have thought, about re- editing it (basically dialing down the sharpening) and reupload it again. But I'm not sure, if this is allowed and I don't want to risk getting blocked. Is it allowed to re- edit an image and re- upload it?
thanks in advance for any response and help! 🙂
Kind regards
Correct answer Ricky336
quote
Hi there!
... Now I have thought, about re- editing it (basically dialing down the sharpening) and reupload it again. But I'm not sure, if this is allowed and I don't want to risk getting blocked. Is it allowed to re- edit an image and re- upload it?
Kind regards
By @NCG_CH
Yes, you can re-edit it and resubmit. Also make sure to check the white balance, noise and artefacts, and any other quality issues before resubmitting.
NCG_CHAuthor
thank you Eva! 🙂
Abambo
quote
thank you Eva! 🙂
By @NCG_CH
Sorry, but Eva is a spammer.
Ricky336
Ricky336Community ExpertCorrect answer
quote
Hi there!
Kind regards
By @NCG_CH
NCG_CHAuthor
thanks a lot, Ricky! I'll do that! 🙂
Ricky336
Just had a quick look - first thing, don't do B&W./greyscale. This can be done by the downloader. Adobe recommends not to add B&W filters. Leave it RGB.
daniellei4510
I'm confused. Can you post the image in question?
Adobe Community Expert | If you can't fix it, hide it; if you can't hide it, delete it.
NCG_CHAuthor
thank you daniellei! so fast answers - didn't expect this! 🙂 I'll add the image, perhaps you might point out some points if you would be so kind - would much aprechiate it!
daniellei4510
Not sure what to tell you about this. I've probably had at least three dozen black and white images accepted, but they were very stylistic and...I don't know...REQUIRED being black and white?. But what I see here is just "mud."  Over processing maybe? Bad cloning? Something isn't quite right.
