When will we have color management for XD?
  • October 16, 2018
  • 9 replies
  • 4330 views
As in the title - when? You add pretty useless stuff like voice control, when we don't have a proper color management for couple of years. Colors look too saturated in XD (different than in Photoshop, Illustrator & browser). Why do we need to get upvotes for you to implement it? It shouldn't take you more than couple days to finish this feature, not to mention years... This is the most annoying thing in your software at the moment. You should first implement stuff that users need ASAP, not waste time on features that we might use once in 10 years (voice control).
Correct answer Atul_Saini
Hi Andyt,
Thanks for using Adobe XD and I will pass on the feedback to the concerned team. I know you don't feel great about it, however, I would really appreciate if you could upvote this feature request: - Color Management (set color profiles) – Adobe XD Feedback : Feature Requests & Bugs if you haven't already.
Atul_Saini
This is extremely basic functionality Adobe...
Common August 2021 and still no Color Managemenet??.
Any Updates???
tot1587691
Still the same problem !! this is is insane...really !!!
anandu.sugathan
Still no update!!? Why Adobe!? I'm switching to Figma
This is beyond frustrating, what's supposely to be the FIRST problem to fix, Adobe just keep dragging it on and on? As of now I'm very tempted to try alternative softwares... and I shouldn't have to in the first place, come on?
This is insane.
Adobe please fix the colour management in XD. Any image I place into XD looks way different than all the other adobe applications or browsers. This should be moved to very top of the development priority list.
BlackR4inbow
100% Agree.
This should have really been a part of this since day one, especially since we share XD files with clients for approval. It's always dissapointing when the colors don't match and clients are asking why? It's not a good reflection on us as designers or Adobe.
HARSHIKA_VERMA
We understand how frustrating it could be. We will share you feedback with the team to make improvements in future. In the meantime please upvote the above mentioned request if you haven't done yet.
Harshika
Same problem. LIKE come on, since 2018?!?! That's XD out the window then ...
I agree you can't design properly. How are you suppose to design anything when you can't tell how colour should look?!
Atul_Saini
Atul_SainiCommunity ManagerCorrect answer
Hi Andyt,
Atul_Saini
casual_Flower98C6
Any updates from this "concerned team"?
