After Affects Wont Render - Please Help
  • June 12, 2023
  • 1199 views
Hi, I hope everyone is well. I use a Macbook,Version 11.7.4, and have After Effects, version 23.4. Whenever I try to render my project, the exported file is glitchy and nonexistent. The rendering itself works yet the product is nothing like what I want to export. How do I fix this?
(video attatched below)
CcyuniAuthor
wait let me try to get a video since this one didnt upload
Jenkmeister
June 12, 2023
Thanks, that's helpful to see.
Can you try switching the Render Queue output to the "High Quality" preset and see if the video is output correctly. Definitely some sort of corruption in the H.264 encoder so it'd be good to know if ProRes outputs correctly.
In terms of fixing this, can you share more details on your hardware? Does the 11.7.4, mean that is the MacOS version you are running on? How old is the Macbook you are using? Is it an Intel machine?
If you go into the Output Module -> Format Options -> Does this still reproduce with Performance Switched from Hardware Encoding to Software Encoding when using H.264?
Jenkmeister
June 12, 2023
I tried and it still failed
Did you try the High Quality preset to export in ProRes format?
Jenkmeister
June 12, 2023
There is a jpeg attached, but no video. Post back once you have a video uploaded so we can see what's going on.
CcyuniAuthor
