After Effects 3D camera tracker problem, frame not analyzed click analyze
  • January 23, 2020
  • 2351 views
Hello everyone,
currently I'm facing another problem with AE that I can't figure out.
I want to 3D camera track my footage to track a title into the scene.
I start tracking the camera movement with my video selected, AE starts analyzing, and every time when finished it shows me this:
The Word to word translation from german to english is: Frame not analyzed, click analyze (what I did a few more times, every time the same message)
I looked up in this community, but just found that other ones had this issue with warp stabilization.
Have I done something wrong or can you help me with this,
Broady
Camera tracking is the first effect you should apply to a layer. Have you turned on Detailed Analysis?
Yes I tried it again with detailed analysis turned on, still doesnt work, still same text "Frame not analyzed, click analyze".
The first effect applied to a layer means that I shouldn't use any other effects before? (I copied my cc and a denoise effect and deleted it from the clip so that I can put the camera tracking first, didn't noticely changed anything)
