Mar 29, 2021 4:00 PM UTC
After Effects has encountered a problem and needs to close. PLEASE HELP!
I have logged in and out of CC, uninstalled the app using creative cloud cleaner tool and restarted my computer and I still cannot open my AE files. I also cant work out how to contact anybody at adobe directly the website is sending me in circles, nightmare !
For reference I am using the most recent version of AE on windows 10.
Pls help I've got a deadline tomorrow.
May 4, 2024 7:19 PM UTC
In my case sapphire plugin was causing the error.
May 4, 2024 7:06 PM UTC
Sorry, in previous post, by mistake i typed unable but you have to disable the all third party plugins.
Hi
Reason for this issue is some plugin error so Disable all third party plugins and restart the after effect and now you can open the file without the error
in AE 2024 you and resolve this issue easy go to the effet tab and disable the all third party plugins and than try to opwn the file
I think This way you can resolve your problem
Thanks
May 4, 2024 7:00 PM UTC
Hi
Reason for this issue is some plugin error so unable all third party plugins and restart the after effect and now you can open the file without the error
Thanks
Mylenium
Mar 29, 2021 4:11 PM UTC
Impossible to know anything. You have not offered exact system info nor any actual crash info. even cropping the screenshot is pretty much useless, as it might already contain a clue to what's going on. you need to do better. Start by checking your system event viewer as well as possibly any Adobe crash logs - if they were ever created and you can find them. anything beyond that will require much more and better info.
Mylenium
Mar 29, 2021 6:16 PM UTC
Hi thanks for taking the time to get back to me. Here is a full screenshot including the crash report, I will paste the full version below. It seems to be something to do with 'EXCEPTION_ACCESS_VIOLATION'
<?xml version="1.0"?>
<!DOCTYPE AdobeCrashReport SYSTEM "AdobeCrashReporter.dtd">
<crashreport serviceVersion="4.7.0" clientVersion="4.7.0" applicationName="After Effects" applicationVersion="18.0.1" build="1" source="Windows-Client" crashType="n/a">
<time year="2021" month="3" day="29" hour="19" minute="9" second="43" timeoffset="0" timezone="GMT Daylight Time"/>
<user guid="01d07bec-125f-49f0-bd52-bd8dc2804608"/>
<system platform="Windows 10 Home" osversion="10.0" osbuild="19042" applicationlanguage="en-us" userlanguage="en-GB" oslanguage="en-US" ram="32693" machine="AMD Ryzen 7 5800X 8-Core Processor" model="AMD64 Family 25 Model 33 Stepping 0" cpuCount="16" cpuType="8664" cpuFreq="3793 MHz" processorArchitecture="9"/>
<gpu>
<gpuinfo availability="Running/Full Power" adapterCompatibility="NVIDIA" adapterRAM="4095 MB" caption="NVIDIA GeForce RTX 3060 Ti" description="NVIDIA GeForce RTX 3060 Ti" driverDate="20201122000000.000000-000" driverVersion="27.21.14.5751" videoModeDescription="2560 x 1440 x 4294967296 colors" pnpDeviceID="PCI&#92;VEN_10DE&#38;DEV_2486&#38;SUBSYS_39711028&#38;REV_A1&#92;4&#38;16D37120&#38;0&#38;0019" installedDisplayDrivers="nvldumdx.dll"/>
</gpu>
<crash exception="EXCEPTION_ACCESS_VIOLATION" exceptionCode="0xc0000005" instruction="0x000000000BB66F76">
<backtrace crashedThread="0">
<thread index="0">
<stackStatement index="0" address="0x000000000BB66F76" symbolname="COR_ACE_Profile::GetProfileColorSpace"/>
<stackStatement index="1" address="0x000000000B9C3344" symbolname="D_YMp_NewOptionsInfo"/>
<stackStatement index="2" address="0x000000000B9B8053" symbolname="PIN_SeqSpec::SetAGMData"/>
<stackStatement index="3" address="0x000000000B9B827A" symbolname="PIN_SeqSpec::SetAGMData"/>
<stackStatement index="4" address="0x000000000B9B7C17" symbolname="PIN_SeqSpec::SetAGMData"/>
<stackStatement index="5" address="0x000000000B9B6CE9" symbolname="PIN_SeqSpec::SetAGMData"/>
<stackStatement index="6" address="0x000000000B9E2A29" symbolname="PIN_IsFrameSolidAlpha"/>
<stackStatement index="7" address="0x000000000B9E20B6" symbolname="PIN_IsFrameSolidAlpha"/>
<stackStatement index="8" address="0x000000000B9E2E49" symbolname="PIN_IsFrameSolidAlpha"/>
<stackStatement index="9" address="0x000000000B9E0E29" symbolname="PIN_DrawFrame"/>
<stackStatement index="10" address="0x000000000B9E1269" symbolname="PIN_DrawSubFrame"/>
<stackStatement index="11" address="0x000000000E28F228" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="12" address="0x000000000E28EAA7" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="13" address="0x000000000E28D0AF" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="14" address="0x000000000E29C355" symbolname="BEE_CheckoutReceipt::pSetReceiptWorld"/>
<stackStatement index="15" address="0x000000000E2D07D0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="16" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="17" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="18" address="0x0000000014291BC5" symbolname="RGp_CheckoutResultImpl::GetWorldGPU"/>
<stackStatement index="19" address="0x000000000BC0EA57" symbolname="FLTp_Node::Render"/>
<stackStatement index="20" address="0x000000000BC0E406" symbolname="FLTp_Node::Render"/>
<stackStatement index="21" address="0x000000000BC0D0BE" symbolname="PropogateLegacyEffectBoundsFromInputNode"/>
<stackStatement index="22" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="23" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="24" address="0x000000001428D5E8" symbolname="RG_CacheNodeBase::Render"/>
<stackStatement index="25" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="26" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="27" address="0x000000001428DF79" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="28" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="29" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="30" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="31" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="32" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="33" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="34" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="35" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="36" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="37" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="38" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="39" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="40" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="41" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="42" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="43" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="44" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="45" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="46" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="47" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="48" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="49" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="50" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="51" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="52" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="53" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="54" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="55" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="56" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="57" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="58" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="59" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="60" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="61" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="62" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="63" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="64" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="65" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="66" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="67" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="68" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="69" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="70" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="71" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="72" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="73" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="74" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="75" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="76" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="77" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="78" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="79" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="80" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="81" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="82" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="83" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="84" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="85" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="86" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="87" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="88" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="89" address="0x000000001429077C" symbolname="RG_Traverser::Execute"/>
<stackStatement index="90" address="0x00000000142930B8" symbolname="RG_ExecuteGraph"/>
<stackStatement index="91" address="0x000000000E2C1BA0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="92" address="0x000000000E2C7B91" symbolname="BEE_SolveOrientation"/>
<stackStatement index="93" address="0x000000000E28F544" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="94" address="0x000000000E28EAA7" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="95" address="0x000000000E28D0AF" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="96" address="0x000000000E29C355" symbolname="BEE_CheckoutReceipt::pSetReceiptWorld"/>
<stackStatement index="97" address="0x000000000E2D07D0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="98" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="99" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="100" address="0x000000001429189F" symbolname="RGp_CheckoutResultImpl::GetWorld"/>
<stackStatement index="101" address="0x0000000014288D2C" symbolname="RG_XformNode::DoRender"/>
<stackStatement index="102" address="0x000000001428DFE1" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="103" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="104" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="105" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="106" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="107" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="108" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="109" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="110" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="111" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="112" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="113" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="114" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="115" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="116" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="117" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="118" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="119" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="120" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="121" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="122" address="0x000000001429077C" symbolname="RG_Traverser::Execute"/>
<stackStatement index="123" address="0x00000000142930B8" symbolname="RG_ExecuteGraph"/>
<stackStatement index="124" address="0x000000000E2C1BA0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="125" address="0x000000000E2C7B91" symbolname="BEE_SolveOrientation"/>
<stackStatement index="126" address="0x000000000E28F544" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="127" address="0x000000000E28EAA7" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="128" address="0x000000000E28D0AF" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="129" address="0x000000000E29C355" symbolname="BEE_CheckoutReceipt::pSetReceiptWorld"/>
<stackStatement index="130" address="0x000000000E2D07D0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="131" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="132" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="133" address="0x000000001429189F" symbolname="RGp_CheckoutResultImpl::GetWorld"/>
<stackStatement index="134" address="0x0000000014288D2C" symbolname="RG_XformNode::DoRender"/>
<stackStatement index="135" address="0x000000001428DFE1" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="136" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="137" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="138" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="139" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="140" address="0x00000000142933BA" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="141" address="0x000000001428DF62" symbolname="RG_CompositeNodeBase::Render"/>
<stackStatement index="142" address="0x000000001429357F" symbolname="RGp_CheckoutResultImpl::Release"/>
<stackStatement index="143" address="0x000000001429077C" symbolname="RG_Traverser::Execute"/>
<stackStatement index="144" address="0x00000000142930B8" symbolname="RG_ExecuteGraph"/>
<stackStatement index="145" address="0x000000000E2C1BA0" symbolname="BEE_SolveOrientation"/>
<stackStatement index="146" address="0x000000000E2C7B91" symbolname="BEE_SolveOrientation"/>
<stackStatement index="147" address="0x000000000E28F544" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="148" address="0x000000000E28EAA7" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="149" address="0x000000000E28D0AF" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="150" address="0x000000000E285341" symbolname="BEE_SetEphemeralCache"/>
<stackStatement index="151" address="0x000000000E27A5F5" symbolname="BEE_CheckoutItemFrame"/>
<stackStatement index="152" address="0x000000000E4ACF1B" symbolname="BEE_RenderState::WorkQueue_SetItemCurrent"/>
<stackStatement index="153" address="0x000000000E4B2759" symbolname="BEE_RenderState::WorkQueue_SetItemCurrent"/>
<stackStatement index="154" address="0x000000000E49F0F8" symbolname="BEEp_WorkQueue_GetRenderGuidWithRO"/>
<stackStatement index="155" address="0x0000000004F80A4A" symbolname="dvacore::threads::CreateAsyncThreadedExecutor"/>
<stackStatement index="156" address="0x0000000004F7DA14" symbolname="dvacore::threads::GetNamedThreadMapSnapshot"/>
<stackStatement index="157" address="0x0000000004F7DE34" symbolname="dvacore::threads::GetNamedThreadMapSnapshot"/>
<stackStatement index="158" address="0x0000000009DA875A" symbolname="boost::detail::win32::handle_manager::swap"/>
<stackStatement index="159" address="0x00007FFEF8621BB2" symbolname="configthreadlocale"/>
<stackStatement index="160" address="0x00007FFEF8CA7034" symbolname="BaseThreadInitThunk"/>
<stackStatement index="161" address="0x00007FFEFAAE2651" symbolname="RtlUserThreadStart"/>
</thread>
</backtrace>
<registerSet>
<register name="RAX" value="0x000000006AAD1E20"/>
<register name="RBX" value="0x00000000B68157B0"/>
<register name="RCX" value="0x0000000000000000"/>
<register name="RDX" value="0x0000000000000000"/>
<register name="RSI" value="0x000000006AAD1F08"/>
<register name="RDI" value="0x000000006AAD1E98"/>
<register name="RSP" value="0x000000006AAD1DD0"/>
<register name="RBP" value="0x0000000000000000"/>
<register name="RIP" value="0x000000000BB66F76"/>
<register name="EFL" value="0x0000000000010202"/>
<register name="LastExceptionToRip" value="0x0000000000000000"/>
<register name="LastExceptionFromRip" value="0x0000000000000000"/>
</registerSet>
<binaryImageSet>
<binaryImage start="0x0000000140000000" end="0x0000000140136000" path="adobe\AfterFX.exe"/>
<binaryImage start="0x00007FFEFAA90000" end="0x00007FFEFAC85000" path="ntdll.dll"/>
<binaryImage start="0x00007FFEF8C90000" end="0x00007FFEF8D4D000" path="kernel32.dll"/>
<binaryImage start="0x00007FFEF8700000" end="0x00007FFEF89C9000" path="KERNELBASE.dll"/>
<binaryImage start="0x00007FFEF8AF0000" end="0x00007FFEF8C90000" path="user32.dll"/>
<binaryImage start="0x00007FFEF8470000" end="0x00007FFEF8492000" path="win32u.dll"/>
<binaryImage start="0x00007FFEF92A0000" end="0x00007FFEF92CA000" path="gdi32.dll"/>
<binaryImage start="0x0000000180000000" end="0x0000000182CF4000" path="adobe\AfterFXLib.dll"/>
<binaryImage start="0x00007FFEF81D0000" end="0x00007FFEF82DB000" path="gdi32full.dll"/>
<binaryImage start="0x00007FFEF8A50000" end="0x00007FFEF8AED000" path="msvcp_win.dll"/>
<binaryImage start="0x00007FFEF8600000" end="0x00007FFEF8700000" path="ucrtbase.dll"/>
<binaryImage start="0x00007FFEAF3E0000" end="0x00007FFEAF471000" path="msvcp140.dll"/>
<binaryImage start="0x00007FFEBD670000" end="0x00007FFEBD689000" path="VCRUNTIME140.dll"/>
<binaryImage start="0x00007FFEFA620000" end="0x00007FFEFA675000" path="shlwapi.dll"/>
<binaryImage start="0x00007FFEC15E0000" end="0x00007FFEC15EC000" path="VCRUNTIME140_1.dll"/>
<binaryImage start="0x00007FFEFA580000" end="0x00007FFEFA61E000" path="msvcrt.dll"/>
<binaryImage start="0x00007FFEFA900000" end="0x00007FFEFA9DA000" path="comdlg32.dll"/>
<binaryImage start="0x00007FFEF9670000" end="0x00007FFEF99C5000" path="combase.dll"/>
<binaryImage start="0x00007FFEEEAD0000" end="0x00007FFEEEAF7000" path="winmm.dll"/>
<binaryImage start="0x00007FFEF9A40000" end="0x00007FFEF9B6B000" path="rpcrt4.dll"/>
<binaryImage start="0x00007FFED6A80000" end="0x00007FFED6A89000" path="wsock32.dll"/>
<binaryImage start="0x00007FFEF99D0000" end="0x00007FFEF9A3B000" path="ws2_32.dll"/>
<binaryImage start="0x00007FFEFA770000" end="0x00007FFEFA81E000" path="SHCore.dll"/>
<binaryImage start="0x00007FFEF9D80000" end="0x00007FFEFA4C2000" path="shell32.dll"/>
<binaryImage start="0x00007FFEECE30000" end="0x00007FFEED0CA000" path="comctl32.dll"/>
<binaryImage start="0x00007FFEF95C0000" end="0x00007FFEF966C000" path="advapi32.dll"/>
<binaryImage start="0x00007FFEF3350000" end="0x00007FFEF3364000" path="wtsapi32.dll"/>
<binaryImage start="0x00007FFEF9CE0000" end="0x00007FFEF9D7C000" path="sechost.dll"/>
<binaryImage start="0x00007FFEF9BA0000" end="0x00007FFEF9CCA000" path="ole32.dll"/>
<binaryImage start="0x00007FFEFA830000" end="0x00007FFEFA8FD000" path="oleaut32.dll"/>
<binaryImage start="0x00007FFEF8390000" end="0x00007FFEF83B7000" path="bcrypt.dll"/>
<binaryImage start="0x00007FFEF84A0000" end="0x00007FFEF85FF000" path="crypt32.dll"/>
<binaryImage start="0x00007FFE58490000" end="0x00007FFE58791000" path="adobe\ahclient.dll"/>
<binaryImage start="0x00007FFE58840000" end="0x00007FFE5895A000" path="adobe\AdobeXMP.dll"/>
<binaryImage start="0x00007FFE54550000" end="0x00007FFE54770000" path="adobe\SynKitLib.dll"/>
<binaryImage start="0x00007FFEF7660000" end="0x00007FFEF769B000" path="IPHLPAPI.DLL"/>
<binaryImage start="0x00007FFEE36D0000" end="0x00007FFEE36DC000" path="secur32.dll"/>
<binaryImage start="0x00007FFEEEB00000" end="0x00007FFEEEC0C000" path="winhttp.dll"/>
<binaryImage start="0x00007FFE54770000" end="0x00007FFE56DC8000" path="adobe\opencv_world410.dll"/>
<binaryImage start="0x00007FFEE5C40000" end="0x00007FFEE611D000" path="wininet.dll"/>
<binaryImage start="0x00007FFE543A0000" end="0x00007FFE54546000" path="adobe\LogSession.dll"/>
<binaryImage start="0x00007FFE570E0000" end="0x00007FFE571C6000" path="adobe\VulcanControl.dll"/>
<binaryImage start="0x00007FFEE7490000" end="0x00007FFEE7538000" path="adobe\VulcanMessage5.dll"/>
<binaryImage start="0x00007FFEF2070000" end="0x00007FFEF207A000" path="version.dll"/>
<binaryImage start="0x00007FFE58440000" end="0x00007FFE5848D000" path="CONCRT140.dll"/>
<binaryImage start="0x00007FFEF8090000" end="0x00007FFEF80CC000" path="sspicli.dll"/>
<binaryImage start="0x00007FFEF7B90000" end="0x00007FFEF7B9C000" path="CRYPTBASE.DLL"/>
<binaryImage start="0x0000000002560000" end="0x0000000002DA3000" path="adobe\EAClient.dll"/>
<binaryImage start="0x0000000003340000" end="0x0000000003479000" path="adobe\DisplaySurface.dll"/>
<binaryImage start="0x0000000002DC0000" end="0x000000000333E000" path="adobe\EAProjectBridge.dll"/>
<binaryImage start="0x0000000003480000" end="0x0000000003561000" path="adobe\MediaFoundation.dll"/>
<binaryImage start="0x0000000003570000" end="0x0000000003609000" path="adobe\VideoFrame.dll"/>
<binaryImage start="0x0000000003640000" end="0x00000000036B5000" path="adobe\ASLFoundation.dll"/>
<binaryImage start="0x00000000036C0000" end="0x00000000048B3000" path="adobe\Backend.dll"/>
<binaryImage start="0x00000000048C0000" end="0x0000000004B4D000" path="adobe\CodecSupport.dll"/>
<binaryImage start="0x0000000004B70000" end="0x0000000004BD4000" path="adobe\MachineLearningUtilities.dll"/>
<binaryImage start="0x0000000004BF0000" end="0x0000000004C1A000" path="adobe\ProjectSupport.dll"/>
<binaryImage start="0x0000000004C30000" end="0x0000000004C6A000" path="adobe\SweetPeaSupport.dll"/>
<binaryImage start="0x0000000004C80000" end="0x0000000004CBC000" path="adobe\MediaUtils.dll"/>
<binaryImage start="0x0000000004CC0000" end="0x0000000004DBA000" path="adobe\dvanet.dll"/>
<binaryImage start="0x0000000004DF0000" end="0x000000000525D000" path="adobe\dvacore.dll"/>
<binaryImage start="0x0000000005260000" end="0x0000000009012000" path="adobe\dvaui.dll"/>
<binaryImage start="0x0000000009020000" end="0x00000000090B8000" path="adobe\aedisplay.dll"/>
<binaryImage start="0x00007FFEF8DB0000" end="0x00007FFEF9219000" path="setupapi.dll"/>
<binaryImage start="0x00000000090E0000" end="0x00000000091D4000" path="adobe\U.dll"/>
<binaryImage start="0x00007FFEF82E0000" end="0x00007FFEF832E000" path="cfgmgr32.dll"/>
<binaryImage start="0x00000000091F0000" end="0x0000000009334000" path="adobe\MEE.dll"/>
<binaryImage start="0x0000000009340000" end="0x00000000096EA000" path="adobe\aelib.dll"/>
<binaryImage start="0x0000000009700000" end="0x0000000009720000" path="adobe\boost_filesystem.dll"/>
<binaryImage start="0x0000000009750000" end="0x00000000097A9000" path="adobe\boost_program_options.dll"/>
<binaryImage start="0x00000000097C0000" end="0x000000000988B000" path="adobe\dvacapsule.dll"/>
<binaryImage start="0x00000000098A0000" end="0x0000000009D60000" path="adobe\dvaaudiodsp.dll"/>
<binaryImage start="0x0000000009D60000" end="0x0000000009D9D000" path="adobe\dvacrashreporter.dll"/>
<binaryImage start="0x0000000009DA0000" end="0x0000000009DB5000" path="adobe\boost_threads.dll"/>
<binaryImage start="0x0000000009DF0000" end="0x0000000009F5A000" path="adobe\dvametadataUI.dll"/>
<binaryImage start="0x0000000009F60000" end="0x0000000009F8B000" path="adobe\dvanetsync.dll"/>
<binaryImage start="0x0000000009F90000" end="0x000000000A1A8000" path="adobe\dvaappsupport.dll"/>
<binaryImage start="0x000000000A1C0000" end="0x000000000A2D8000" path="adobe\dvamediatypes.dll"/>
<binaryImage start="0x000000000A310000" end="0x000000000A497000" path="adobe\dvaaudiodevice.dll"/>
<binaryImage start="0x000000000A4A0000" end="0x000000000A6EE000" path="adobe\dynamiclink.dll"/>
<binaryImage start="0x000000000A6F0000" end="0x000000000A7A2000" path="adobe\dvaplayer.dll"/>
<binaryImage start="0x000000000A7C0000" end="0x000000000A829000" path="adobe\dvatemporalxmp.dll"/>
<binaryImage start="0x000000000A870000" end="0x000000000AADD000" path="adobe\dvascripting.dll"/>
<binaryImage start="0x000000000AAE0000" end="0x000000000AB1A000" path="adobe\dvatypekit.dll"/>
<binaryImage start="0x000000000AB20000" end="0x000000000AB51000" path="adobe\dvatexteditor.dll"/>
<binaryImage start="0x000000000AB60000" end="0x000000000AC30000" path="adobe\dvaeve.dll"/>
<binaryImage start="0x000000000AC50000" end="0x000000000AE28000" path="adobe\dvaworkspace.dll"/>
<binaryImage start="0x000000000AE40000" end="0x000000000B306000" path="adobe\exo.dll"/>
<binaryImage start="0x000000000B320000" end="0x000000000B38B000" path="adobe\dynamiclinkUI.dll"/>
<binaryImage start="0x000000000B390000" end="0x000000000B5A2000" path="adobe\dvauxphost.dll"/>
<binaryImage start="0x000000000B5D0000" end="0x000000000B6A7000" path="adobe\drawbotagm.dll"/>
<binaryImage start="0x000000000B6C0000" end="0x000000000B794000" path="adobe\dvamlprocessing.dll"/>
<binaryImage start="0x000000000B7A0000" end="0x000000000B7A9000" path="adobe\SAM.dll"/>
<binaryImage start="0x000000000B7E0000" end="0x000000000B815000" path="adobe\FILE.dll"/>
<binaryImage start="0x000000000B820000" end="0x000000000B83F000" path="adobe\PREF.dll"/>
<binaryImage start="0x000000000B840000" end="0x000000000B860000" path="adobe\PR.dll"/>
<binaryImage start="0x000000000B890000" end="0x000000000B8F4000" path="adobe\SLU.dll"/>
<binaryImage start="0x000000000B900000" end="0x000000000BB59000" path="adobe\PIN.dll"/>
<binaryImage start="0x000000000BB60000" end="0x000000000BBAC000" path="adobe\COR.dll"/>
<binaryImage start="0x000000000BBD0000" end="0x000000000BCBC000" path="adobe\FLT.dll"/>
<binaryImage start="0x000000000BCC0000" end="0x000000000C011000" path="adobe\PF.dll"/>
<binaryImage start="0x000000000C040000" end="0x000000000C08D000" path="adobe\OM.dll"/>
<binaryImage start="0x000000000C0A0000" end="0x000000000C0CB000" path="adobe\P.dll"/>
<binaryImage start="0x000000000C0D0000" end="0x000000000D726000" path="adobe\FRP.dll"/>
<binaryImage start="0x000000000D750000" end="0x000000000D7B3000" path="adobe\MC.dll"/>
<binaryImage start="0x000000000D7C0000" end="0x000000000D7EB000" path="adobe\BEZ.dll"/>
<binaryImage start="0x000000000D810000" end="0x000000000D8DF000" path="adobe\MSK.dll"/>
<binaryImage start="0x000000000D8F0000" end="0x000000000D967000" path="adobe\TDB.dll"/>
<binaryImage start="0x000000000D970000" end="0x000000000D9A0000" path="adobe\SND.dll"/>
<binaryImage start="0x000000000D9C0000" end="0x000000000EAB5000" path="adobe\BEE.dll"/>
<binaryImage start="0x000000000EAD0000" end="0x000000000EE26000" path="adobe\TXT.dll"/>
<binaryImage start="0x000000000EE30000" end="0x000000000EE6D000" path="adobe\PREM.dll"/>
<binaryImage start="0x00007FFEF9B70000" end="0x00007FFEF9BA0000" path="imm32.dll"/>
<binaryImage start="0x000000000EE90000" end="0x000000000EF8A000" path="adobe\dvaaudiodeviceui.dll"/>
<binaryImage start="0x000000000EF90000" end="0x000000000EFED000" path="adobe\AdobeOldGPU.dll"/>
<binaryImage start="0x000000000F000000" end="0x000000000F00E000" path="adobe\LIST.dll"/>
<binaryImage start="0x000000000F020000" end="0x000000000F03A000" path="adobe\PLUG.dll"/>
<binaryImage start="0x00007FFE57470000" end="0x00007FFE5751F000" path="adobe\AdobeXMPCompareAndMerge.dll"/>
<binaryImage start="0x00007FFE8A3B0000" end="0x00007FFE8A4D6000" path="opengl32.dll"/>
<binaryImage start="0x00007FFEF4090000" end="0x00007FFEF4650000" path="d2d1.dll"/>
<binaryImage start="0x00007FFED6D50000" end="0x00007FFED6FCF000" path="DWrite.dll"/>
<binaryImage start="0x00007FFEF5E60000" end="0x00007FFEF5E8F000" path="dwmapi.dll"/>
<binaryImage start="0x00007FFEF39C0000" end="0x00007FFEF3C24000" path="d3d11.dll"/>
<binaryImage start="0x00007FFEF57B0000" end="0x00007FFEF57D0000" path="D3D12.dll"/>
<binaryImage start="0x00007FFEF6B20000" end="0x00007FFEF6C13000" path="dxgi.dll"/>
<binaryImage start="0x00007FFEDA820000" end="0x00007FFEDA83D000" path="mpr.dll"/>
<binaryImage start="0x00007FFEF3C30000" end="0x00007FFEF408D000" path="D3DCOMPILER_47.dll"/>
<binaryImage start="0x00007FFEF2C30000" end="0x00007FFEF2C5B000" path="msvfw32.dll"/>
<binaryImage start="0x00007FFEC9A60000" end="0x00007FFEC9C1C000" path="mfplat.dll"/>
<binaryImage start="0x00007FFE533A0000" end="0x00007FFE54392000" path="adobe\mc_dec_mp2v.dll"/>
<binaryImage start="0x00007FFE52150000" end="0x00007FFE53399000" path="adobe\mc_dec_avc.dll"/>
<binaryImage start="0x00007FFE51190000" end="0x00007FFE52147000" path="adobe\mc_dec_mp4v.dll"/>
<binaryImage start="0x00007FFE509C0000" end="0x00007FFE51181000" path="adobe\DNxHR.dll"/>
<binaryImage start="0x00007FFE50770000" end="0x00007FFE509BF000" path="adobe\SonyRawDev.dll"/>
<binaryImage start="0x00007FFE4EFD0000" end="0x00007FFE4FE78000" path="adobe\CrmSdk.dll"/>
<binaryImage start="0x00007FFE50620000" end="0x00007FFE5076A000" path="adobe\kdu_vs7AR.dll"/>
<binaryImage start="0x00007FFEF79C0000" end="0x00007FFEF7A2A000" path="mswsock.dll"/>
<binaryImage start="0x00007FFE4FE80000" end="0x00007FFE4FE9E000" path="msacm32.dll"/>
<binaryImage start="0x00007FFEE63C0000" end="0x00007FFEE65A4000" path="dbghelp.dll"/>
<binaryImage start="0x00007FFEF5850000" end="0x00007FFEF5857000" path="MSVCP140_CODECVT_IDS.dll"/>
<binaryImage start="0x00007FFE50370000" end="0x00007FFE50614000" path="adobe\ZXPSignLib-minimal.dll"/>
<binaryImage start="0x00007FFEED120000" end="0x00007FFEED2CB000" path="GdiPlus.dll"/>
<binaryImage start="0x00007FFEEE060000" end="0x00007FFEEE08E000" path="adobe\BIB.dll"/>
<binaryImage start="0x0000000074B90000" end="0x0000000074BB5000" path="adobe\AXE8SharedExpat.dll"/>
<binaryImage start="0x00007FFE583F0000" end="0x00007FFE58435000" path="adobe\tbb.dll"/>
<binaryImage start="0x00007FFE58290000" end="0x00007FFE58307000" path="adobe\CRClient.dll"/>
<binaryImage start="0x00007FFE4EA70000" end="0x00007FFE4EFC1000" path="adobe\PlugPlug.dll"/>
<binaryImage start="0x00007FFE4FF20000" end="0x00007FFE5036E000" path="adobe\libmmd.dll"/>
<binaryImage start="0x00007FFEF2740000" end="0x00007FFEF274A000" path="avrt.dll"/>
<binaryImage start="0x00007FFE4BDF0000" end="0x00007FFE4EA62000" path="adobe\dynamic-torqnative.dll"/>
<binaryImage start="0x0000000074AC0000" end="0x0000000074B88000" path="adobe\AXEDOMCore.dll"/>
<binaryImage start="0x00007FFEF8330000" end="0x00007FFEF8390000" path="wintrust.dll"/>
<binaryImage start="0x00007FFEF9CD0000" end="0x00007FFEF9CD8000" path="psapi.dll"/>
<binaryImage start="0x00007FFE4B2D0000" end="0x00007FFE4BDE3000" path="adobe\AdobePDFL.dll"/>
<binaryImage start="0x00007FFE57270000" end="0x00007FFE572CA000" path="adobe\ARE.dll"/>
<binaryImage start="0x00007FFE480A0000" end="0x00007FFE4B2D0000" path="adobe\AdobePIE.dll"/>
<binaryImage start="0x00007FFE47FF0000" end="0x00007FFE48095000" path="adobe\JP2KLib.dll"/>
<binaryImage start="0x00007FFE47E70000" end="0x00007FFE47FE8000" path="adobe\AdobeXMPFiles.dll"/>
<binaryImage start="0x00007FFE479A0000" end="0x00007FFE47E61000" path="adobe\MPS.dll"/>
<binaryImage start="0x00000000748E0000" end="0x0000000074ABB000" path="adobe\icucnv64.dll"/>
<binaryImage start="0x0000000074680000" end="0x00000000748D8000" path="adobe\icuuc64.dll"/>
<binaryImage start="0x00007FFECACC0000" end="0x00007FFECACEC000" path="glu32.dll"/>
<binaryImage start="0x00007FFEF6150000" end="0x00007FFEF6162000" path="kernel.appcore.dll"/>
<binaryImage start="0x00007FFEF7BA0000" end="0x00007FFEF7BB8000" path="cryptsp.dll"/>
<binaryImage start="0x00007FFE478F0000" end="0x00007FFE47997000" path="msvcp110.dll"/>
<binaryImage start="0x00007FFE47810000" end="0x00007FFE478E4000" path="msvcr110.dll"/>
<binaryImage start="0x00007FFE4FEC0000" end="0x00007FFE4FF1D000" path="adobe\cudart64_75.dll"/>
<binaryImage start="0x00007FFEECDA0000" end="0x00007FFEECE2E000" path="winspool.drv"/>
<binaryImage start="0x00007FFEECD30000" end="0x00007FFEECD96000" path="oleacc.dll"/>
<binaryImage start="0x00007FFEF16F0000" end="0x00007FFEF16F7000" path="msimg32.dll"/>
<binaryImage start="0x00007FFEF5BF0000" end="0x00007FFEF5C8E000" path="uxtheme.dll"/>
<binaryImage start="0x00007FFE47600000" end="0x00007FFE4780F000" path="adobe\libiomp5md.dll"/>
<binaryImage start="0x00007FFEE6230000" end="0x00007FFEE6256000" path="winmmbase.dll"/>
<binaryImage start="0x00007FFEF80D0000" end="0x00007FFEF80FE000" path="userenv.dll"/>
<binaryImage start="0x00007FFEF48C0000" end="0x00007FFEF49B7000" path="propsys.dll"/>
<binaryImage start="0x00007FFEC6650000" end="0x00007FFEC6661000" path="credui.dll"/>
<binaryImage start="0x00007FFEE50C0000" end="0x00007FFEE52AE000" path="urlmon.dll"/>
<binaryImage start="0x00007FFE587D0000" end="0x00007FFE58800000" path="adobe\BIBUtils.dll"/>
<binaryImage start="0x00007FFE47440000" end="0x00007FFE475F9000" path="adobe\ACE.dll"/>
<binaryImage start="0x00007FFE46C90000" end="0x00007FFE47440000" path="adobe\AGM.dll"/>
<binaryImage start="0x00007FFE46730000" end="0x00007FFE467A5000" path="adobe\AdobeSVGAGM.dll"/>
<binaryImage start="0x00007FFE467B0000" end="0x00007FFE46857000" path="adobe\pdfsettings.dll"/>
<binaryImage start="0x00007FFE46860000" end="0x00007FFE46C84000" path="adobe\CoolType.dll"/>
<binaryImage start="0x00007FFE46360000" end="0x00007FFE46721000" path="adobe\AIDE.dll"/>
<binaryImage start="0x00007FFE45070000" end="0x00007FFE46354000" path="adobe\usd_win.dll"/>
<binaryImage start="0x000000004AD00000" end="0x000000004C744000" path="adobe\icudt64.dll"/>
<binaryImage start="0x00007FFEE4E10000" end="0x00007FFEE50C0000" path="iertutil.dll"/>
<binaryImage start="0x0000000074280000" end="0x000000007467F000" path="adobe\SVGRE.dll"/>
<binaryImage start="0x00007FFEF1E80000" end="0x00007FFEF2034000" path="WindowsCodecs.dll"/>
<binaryImage start="0x00007FFEF7FD0000" end="0x00007FFEF7FDA000" path="dpapi.dll"/>
<binaryImage start="0x000000000F240000" end="0x000000000F265000" path="adobe\TeamProjectsLocalClient.dll"/>
<binaryImage start="0x000000000F290000" end="0x000000000F299000" path="adobe\PRM.dll"/>
<binaryImage start="0x000000000F2A0000" end="0x000000000F2CC000" path="adobe\dvamarshal.dll"/>
<binaryImage start="0x000000000F2D0000" end="0x000000000F32E000" path="adobe\CSXSManager.dll"/>
<binaryImage start="0x000000000F330000" end="0x000000000F370000" path="adobe\dvavulcansupport.dll"/>
<binaryImage start="0x000000000F3B0000" end="0x000000000F6C7000" path="adobe\ImageRenderer.dll"/>
<binaryImage start="0x000000000F6D0000" end="0x000000000F83E000" path="adobe\ColorSpaceConverter.dll"/>
<binaryImage start="0x000000000F840000" end="0x000000000F862000" path="adobe\GPUAnalytics.dll"/>
<binaryImage start="0x000000000F870000" end="0x000000000FA0E000" path="adobe\dvastorage.dll"/>
<binaryImage start="0x000000000FA30000" end="0x000000000FAC6000" path="adobe\utest.dll"/>
<binaryImage start="0x000000000FAE0000" end="0x000000000FFCF000" path="adobe\GPUFoundation.dll"/>
<binaryImage start="0x000000000FFE0000" end="0x0000000010027000" path="adobe\ImmersiveVideo.dll"/>
<binaryImage start="0x0000000010040000" end="0x0000000010056000" path="adobe\ACEWrapper.dll"/>
<binaryImage start="0x0000000010060000" end="0x000000001006D000" path="adobe\Memory.dll"/>
<binaryImage start="0x00000000100A0000" end="0x000000001011F000" path="adobe\DynamicLinkMedia.dll"/>
<binaryImage start="0x0000000010130000" end="0x000000001028F000" path="adobe\MBCProvider.dll"/>
<binaryImage start="0x0000000010290000" end="0x000000001044B000" path="adobe\EncoderHost.dll"/>
<binaryImage start="0x0000000010450000" end="0x0000000010718000" path="adobe\EAMedia.dll"/>
<binaryImage start="0x0000000010730000" end="0x00000000108F9000" path="adobe\ImporterHost.dll"/>
<binaryImage start="0x0000000010920000" end="0x00000000109F1000" path="adobe\PluginSupport.dll"/>
<binaryImage start="0x0000000010A00000" end="0x0000000010BAA000" path="adobe\VideoRenderer.dll"/>
<binaryImage start="0x0000000010BD0000" end="0x0000000010D8E000" path="adobe\CloudMediaClient.dll"/>
<binaryImage start="0x0000000010D90000" end="0x0000000010DBA000" path="adobe\RuntimeInstaller.dll"/>
<binaryImage start="0x0000000010DD0000" end="0x0000000010EA1000" path="adobe\ProResOpt.dll"/>
<binaryImage start="0x0000000010EC0000" end="0x0000000010FE8000" path="adobe\mp4decoder_dll.dll"/>
<binaryImage start="0x0000000011010000" end="0x00000000111DC000" path="adobe\CFHDDecoder64.dll"/>
<binaryImage start="0x00000000111E0000" end="0x000000001133F000" path="adobe\kdu_as7AR.dll"/>
<binaryImage start="0x0000000011350000" end="0x0000000012231000" path="adobe\dvaaccelerate.dll"/>
<binaryImage start="0x0000000012260000" end="0x0000000012294000" path="adobe\dvaalgebra.dll"/>
<binaryImage start="0x00000000122A0000" end="0x0000000012347000" path="adobe\dvamachinelearning.dll"/>
<binaryImage start="0x0000000012360000" end="0x00000000123CC000" path="adobe\AudioFilterHost.dll"/>
<binaryImage start="0x00000000123F0000" end="0x000000001257B000" path="adobe\VideoFilterHost.dll"/>
<binaryImage start="0x0000000012580000" end="0x000000001270E000" path="adobe\dvacaptioning.dll"/>
<binaryImage start="0x0000000012720000" end="0x00000000127C1000" path="adobe\boost_regex.dll"/>
<binaryImage start="0x0000000012800000" end="0x0000000012EB8000" path="adobe\MLFoundation.dll"/>
<binaryImage start="0x0000000012EC0000" end="0x0000000012EED000" path="adobe\GPUKernels.dll"/>
<binaryImage start="0x0000000012EF0000" end="0x000000001301F000" path="adobe\AudioRenderer.dll"/>
<binaryImage start="0x0000000013040000" end="0x000000001313A000" path="adobe\dvametadata.dll"/>
<binaryImage start="0x0000000013140000" end="0x00000000133EA000" path="adobe\xerces.dll"/>
<binaryImage start="0x0000000013400000" end="0x0000000013425000" path="adobe\libzip.dll"/>
<binaryImage start="0x0000000013450000" end="0x00000000134E4000" path="adobe\TDL.dll"/>
<binaryImage start="0x00000000134F0000" end="0x0000000013549000" path="adobe\boost_serialization.dll"/>
<binaryImage start="0x0000000013570000" end="0x000000001357C000" path="adobe\VAL.dll"/>
<binaryImage start="0x0000000013580000" end="0x000000001360C000" path="adobe\FLO.dll"/>
<binaryImage start="0x0000000013620000" end="0x0000000013759000" path="adobe\dvametadataDB.dll"/>
<binaryImage start="0x0000000013780000" end="0x0000000013920000" path="adobe\cclibmanager.dll"/>
<binaryImage start="0x0000000013920000" end="0x0000000013982000" path="adobe\dvatransport.dll"/>
<binaryImage start="0x00000000139B0000" end="0x00000000139C3000" path="adobe\dvabravoinitializer.dll"/>
<binaryImage start="0x00000000139D0000" end="0x0000000013BAF000" path="adobe\ExportSettings.dll"/>
<binaryImage start="0x0000000013BC0000" end="0x0000000013F3E000" path="adobe\SettingsUI.dll"/>
<binaryImage start="0x0000000013F50000" end="0x0000000014247000" path="adobe\RendererGPU.dll"/>
<binaryImage start="0x0000000014270000" end="0x00000000142B5000" path="adobe\RG.dll"/>
<binaryImage start="0x00000000142C0000" end="0x0000000014315000" path="adobe\AudioSupport.dll"/>
<binaryImage start="0x0000000014340000" end="0x00000000143CB000" path="adobe\PlayerHost.dll"/>
<binaryImage start="0x00000000143D0000" end="0x00000000143EF000" path="adobe\ProjectConverterHost.dll"/>
<binaryImage start="0x0000000014410000" end="0x0000000014487000" path="adobe\TransmitHost.dll"/>
<binaryImage start="0x0000000014490000" end="0x0000000014572000" path="adobe\ExporterHost.dll"/>
<binaryImage start="0x00000000145A0000" end="0x0000000014878000" path="adobe\WRServices.dll"/>
<binaryImage start="0x0000000014880000" end="0x00000000148F2000" path="adobe\aif_core.dll"/>
<binaryImage start="0x0000000014920000" end="0x00000000149B3000" path="adobe\aif_ogl.dll"/>
<binaryImage start="0x00000000149C0000" end="0x0000000014D16000" path="adobe\glbinding.dll"/>
<binaryImage start="0x0000000014D30000" end="0x0000000014DD0000" path="adobe\extendscript.dll"/>
<binaryImage start="0x0000000014DE0000" end="0x0000000014E8C000" path="adobe\sccore.dll"/>
<binaryImage start="0x00007FFE45000000" end="0x00007FFE4506C000" path="adobe\cudart64_101.dll"/>
<binaryImage start="0x00007FFE44D60000" end="0x00007FFE44ECF000" path="adobe\mc_mfimport.dll"/>
<binaryImage start="0x00007FFE43B50000" end="0x00007FFE44D5D000" path="adobe\svml_dispmd.dll"/>
<binaryImage start="0x00007FFEE4BD0000" end="0x00007FFEE4BFC000" path="dbgcore.dll"/>
<binaryImage start="0x0000000014EE0000" end="0x0000000014F55000" path="adobe\ubench.dll"/>
<binaryImage start="0x0000000014F60000" end="0x0000000014F74000" path="adobe\CCLibrariesSupport.dll"/>
<binaryImage start="0x0000000014FA0000" end="0x0000000014FCE000" path="adobe\TimeCarving.dll"/>
<binaryImage start="0x0000000014FD0000" end="0x00000000152D2000" path="adobe\ATEWrapper.dll"/>
<binaryImage start="0x00000000152E0000" end="0x0000000015308000" path="adobe\LUTManager.dll"/>
<binaryImage start="0x0000000015350000" end="0x0000000015416000" path="adobe\OpticalFlow.dll"/>
<binaryImage start="0x0000000015420000" end="0x000000001547B000" path="adobe\senseisdk.dll"/>
<binaryImage start="0x0000000015490000" end="0x0000000015572000" path="adobe\dvaaudiofilterhost.dll"/>
<binaryImage start="0x00000000155A0000" end="0x00000000157B2000" path="adobe\dvaaudiofilters.dll"/>
<binaryImage start="0x00000000159F0000" end="0x0000000015A34000" path="adobe\AMEAppFoundation.dll"/>
<binaryImage start="0x0000000015A40000" end="0x0000000015A61000" path="adobe\dvaexporttracker.dll"/>
<binaryImage start="0x0000000015AA0000" end="0x0000000015ABD000" path="adobe\atl_audio.dll"/>
<binaryImage start="0x0000000015AC0000" end="0x0000000015E7F000" path="adobe\EACodec.dll"/>
<binaryImage start="0x0000000015E90000" end="0x0000000016189000" path="adobe\LUTEngine.dll"/>
<binaryImage start="0x00007FFEE61C0000" end="0x00007FFEE61D8000" path="netapi32.dll"/>
<binaryImage start="0x00007FFEF76A0000" end="0x00007FFEF76AC000" path="netutils.dll"/>
<binaryImage start="0x00007FFEF89D0000" end="0x00007FFEF8A50000" path="bcryptPrimitives.dll"/>
<binaryImage start="0x00007FFED0830000" end="0x00007FFED092C000" path="DellInc.AlienwareSoundCenterDevProps2.dll"/>
<binaryImage start="0x00007FFED4610000" end="0x00007FFED46BC000" path="NahimicOSD.dll"/>
<binaryImage start="0x00007FFED78E0000" end="0x00007FFED7901000" path="ProductInfo.dll"/>
<binaryImage start="0x00000000181F0000" end="0x0000000018242000" path="adobe\dvasystemcompatibilityreport.DLL"/>
<binaryImage start="0x00007FFEC9E10000" end="0x00007FFEC9E40000" path="RTWorkQ.dll"/>
<binaryImage start="0x00007FFE57F20000" end="0x00007FFE57F64000" path="adobe\tbbmalloc.dll"/>
<binaryImage start="0x00007FFEF72F0000" end="0x00007FFEF7324000" path="rsaenh.dll"/>
<binaryImage start="0x00007FFEF7DC0000" end="0x00007FFEF7DD2000" path="msasn1.dll"/>
<binaryImage start="0x0000000019410000" end="0x0000000019462000" path="adobe\dvascriptingNAPI.DLL"/>
<binaryImage start="0x0000000019BC0000" end="0x0000000019DC3000" path="adobe\dvauxpui.dll"/>
<binaryImage start="0x00007FFEF6350000" end="0x00007FFEF6AE0000" path="windows.storage.dll"/>
<binaryImage start="0x00007FFEF7C40000" end="0x00007FFEF7C6C000" path="wldp.dll"/>
<binaryImage start="0x00007FFEF8110000" end="0x00007FFEF812F000" path="profapi.dll"/>
<binaryImage start="0x00007FFEF92D0000" end="0x00007FFEF93E5000" path="msctf.dll"/>
<binaryImage start="0x00007FFEF6F90000" end="0x00007FFEF6FEA000" path="winsta.dll"/>
<binaryImage start="0x00007FFEFA4D0000" end="0x00007FFEFA579000" path="clbcatq.dll"/>
<binaryImage start="0x00007FFEDBA40000" end="0x00007FFEDBA7E000" path="dataexchange.dll"/>
<binaryImage start="0x00007FFEF4D30000" end="0x00007FFEF4F17000" path="dcomp.dll"/>
<binaryImage start="0x00007FFEF21B0000" end="0x00007FFEF23B1000" path="twinapi.appcore.dll"/>
<binaryImage start="0x00007FFED8BC0000" end="0x00007FFED8C6C000" path="TextShaping.dll"/>
<binaryImage start="0x00007FFEF20D0000" end="0x00007FFEF20DB000" path="winnsi.dll"/>
<binaryImage start="0x00007FFEFAA40000" end="0x00007FFEFAA48000" path="nsi.dll"/>
<binaryImage start="0x00007FFEF1A20000" end="0x00007FFEF1A37000" path="dhcpcsvc6.DLL"/>
<binaryImage start="0x00007FFEF1BD0000" end="0x00007FFEF1BED000" path="dhcpcsvc.dll"/>
<binaryImage start="0x00007FFEE59B0000" end="0x00007FFEE5A4D000" path="webio.dll"/>
<binaryImage start="0x00007FFEF76B0000" end="0x00007FFEF777B000" path="dnsapi.dll"/>
<binaryImage start="0x00007FFEEC380000" end="0x00007FFEEC38A000" path="rasadhlp.dll"/>
<binaryImage start="0x00007FFEEC750000" end="0x00007FFEEC7CF000" path="FWPUCLNT.DLL"/>
<binaryImage start="0x00007FFEAF1D0000" end="0x00007FFEAF3DC000" path="msxml3.dll"/>
<binaryImage start="0x00007FFEF7210000" end="0x00007FFEF72A1000" path="schannel.dll"/>
<binaryImage start="0x00007FFED8E40000" end="0x00007FFED8E55000" path="mskeyprotect.dll"/>
<binaryImage start="0x00007FFEF7C70000" end="0x00007FFEF7CAB000" path="ntasn1.dll"/>
<binaryImage start="0x00007FFEF7CB0000" end="0x00007FFEF7CD7000" path="ncrypt.dll"/>
<binaryImage start="0x00007FFEC7BB0000" end="0x00007FFEC7BD6000" path="ncryptsslp.dll"/>
<binaryImage start="0x00007FFEF1B90000" end="0x00007FFEF1BC1000" path="cryptnet.dll"/>
<binaryImage start="0x00007FFEF93F0000" end="0x00007FFEF940D000" path="imagehlp.dll"/>
<binaryImage start="0x00007FFEEF6F0000" end="0x00007FFEEF72B000" path="DXCore.dll"/>
<binaryImage start="0x00007FFEF2910000" end="0x00007FFEF2A0A000" path="AppXDeploymentClient.dll"/>
<binaryImage start="0x00007FFE40DF0000" end="0x00007FFE43AD0000" path="nvoglv64.dll"/>
<binaryImage start="0x00007FFEF7F80000" end="0x00007FFEF7FAC000" path="devobj.dll"/>
<binaryImage start="0x00007FFEF6F20000" end="0x00007FFEF6F53000" path="ntmarta.dll"/>
<binaryImage start="0x00007FFEF77D0000" end="0x00007FFEF781B000" path="powrprof.dll"/>
<binaryImage start="0x00007FFEF7640000" end="0x00007FFEF7652000" path="umpdc.dll"/>
<binaryImage start="0x00007FFE57090000" end="0x00007FFE570D8000" path="adobe\mc_enc_dv.dll"/>
<binaryImage start="0x00007FFE40D20000" end="0x00007FFE40DEB000" path="nvEncodeAPI64.dll"/>
<binaryImage start="0x00007FFE409A0000" end="0x00007FFE40C07000" path="nvcuda.dll"/>
<binaryImage start="0x00007FFE3F470000" end="0x00007FFE4099C000" path="nvcuda64.dll"/>
<binaryImage start="0x00007FFEEB5F0000" end="0x00007FFEEBCC6000" path="nvapi64.dll"/>
<binaryImage start="0x00007FFEEF3C0000" end="0x00007FFEEF4C2000" path="nvldumdx.dll"/>
<binaryImage start="0x00007FFEBABA0000" end="0x00007FFEBD661000" path="nvwgf2umx.dll"/>
<binaryImage start="0x00007FFE3F130000" end="0x00007FFE3F46D000" path="adobe\REDR3D-x64.dll"/>
<binaryImage start="0x00007FFE3E460000" end="0x00007FFE3F128000" path="adobe\REDCuda-x64.dll"/>
<binaryImage start="0x00007FFE3E370000" end="0x00007FFE3E45F000" path="msvcr120.dll"/>
<binaryImage start="0x00007FFE3E2C0000" end="0x00007FFE3E366000" path="msvcp120.dll"/>
<binaryImage start="0x00007FFE3E010000" end="0x00007FFE3E2B2000" path="adobe\REDOpenCL-x64.dll"/>
<binaryImage start="0x00000000233B0000" end="0x00000000233CF000" path="adobe\ExporterAVI.prm"/>
<binaryImage start="0x00000000230D0000" end="0x00000000230DB000" path="adobe\VfWFileWriter.dll"/>
<binaryImage start="0x0000000023590000" end="0x00000000235EF000" path="adobe\ExporterQuickTimeHost.prm"/>
<binaryImage start="0x00000000542E0000" end="0x00000000544F5000" path="adobe\CFHDEncoder64.dll"/>
<binaryImage start="0x0000000024480000" end="0x000000002449A000" path="adobe\QTWriter.dll"/>
<binaryImage start="0x00000000307C0000" end="0x0000000030826000" path="adobe\ImporterAVI.prm"/>
<binaryImage start="0x0000000055BB0000" end="0x0000000055D3C000" path="adobe\ImporterRED.prm"/>
<binaryImage start="0x0000000029AA0000" end="0x0000000029AC5000" path="adobe\ImporterSensorManager.prm"/>
<binaryImage start="0x00007FFE3DF00000" end="0x00007FFE3E008000" path="adobe\AdobeSensorManager.dll"/>
<binaryImage start="0x0000000030840000" end="0x0000000030859000" path="adobe\ImporterWindowsMedia.prm"/>
<binaryImage start="0x00007FFEF1130000" end="0x00007FFEF1389000" path="WMVCORE.DLL"/>
<binaryImage start="0x00007FFEF1040000" end="0x00007FFEF1095000" path="WMASF.DLL"/>
<binaryImage start="0x00007FFEF0BB0000" end="0x00007FFEF0CDD000" path="mfperfhelper.dll"/>
<binaryImage start="0x00007FFE89650000" end="0x00007FFE89820000" path="quartz.dll"/>
<binaryImage start="0x0000000029970000" end="0x0000000029979000" path="adobe\TransmitDesktopAudio.prm"/>
<binaryImage start="0x0000000029990000" end="0x0000000029A00000" path="adobe\PlayerMediaCore.prm"/>
<binaryImage start="0x00000000327C0000" end="0x00000000327FC000" path="adobe\RendererCPU.dll"/>
<binaryImage start="0x0000000032800000" end="0x0000000032828000" path="adobe\TransmitDV.prm"/>
<binaryImage start="0x00007FFEF2FF0000" end="0x00007FFEF300D000" path="devenum.dll"/>
<binaryImage start="0x00007FFECF3A0000" end="0x00007FFECF3AB000" path="msdmo.dll"/>
<binaryImage start="0x0000000032840000" end="0x000000003284E000" path="adobe\TransmitFullScreen.prm"/>
<binaryImage start="0x000000005E990000" end="0x000000005F6BA000" path="adobe\TransmitScopes.prm"/>
<binaryImage start="0x0000000032A40000" end="0x0000000032A57000" path="adobe\TransmitVR.prm"/>
<binaryImage start="0x0000000053F50000" end="0x0000000053FE8000" path="adobe\VRCore.dll"/>
<binaryImage start="0x00007FFEF2F90000" end="0x00007FFEF2FCE000" path="netprofm.dll"/>
<binaryImage start="0x00007FFEF19D0000" end="0x00007FFEF19E0000" path="npmproxy.dll"/>
<binaryImage start="0x00007FFEF18D0000" end="0x00007FFEF1955000" path="MMDevAPI.dll"/>
<binaryImage start="0x00007FFEF1450000" end="0x00007FFEF15D5000" path="AudioSes.dll"/>
<binaryImage start="0x00007FFEF5D70000" end="0x00007FFEF5D84000" path="resourcepolicyclient.dll"/>
<binaryImage start="0x00007FFE44F40000" end="0x00007FFE44F86000" path="wdmaud.drv"/>
<binaryImage start="0x00007FFEEEC80000" end="0x00007FFEEEC89000" path="ksuser.dll"/>
<binaryImage start="0x00007FFEA34A0000" end="0x00007FFEA34AD000" path="msacm32.drv"/>
<binaryImage start="0x00007FFE9CD10000" end="0x00007FFE9CD1B000" path="midimap.dll"/>
<binaryImage start="0x00007FFE71290000" end="0x00007FFE7132C000" path="dsound.dll"/>
<binaryImage start="0x000000004ACE0000" end="0x000000004ACEF000" path="adobe\ExporterAIFF.prm"/>
<binaryImage start="0x00000000560B0000" end="0x0000000056164000" path="adobe\ExporterMP3.prm"/>
<binaryImage start="0x0000000054290000" end="0x00000000542AA000" path="adobe\ExporterWave.prm"/>
<binaryImage start="0x0000000074BC0000" end="0x000000007C900000" path="adobe\Camera Raw.8bi"/>
<binaryImage start="0x00007FFE76B30000" end="0x00007FFE76CFD000" path="D3D12Core.dll"/>
<binaryImage start="0x00007FFE59720000" end="0x00007FFE5974B000" path="D3DSCache.dll"/>
<binaryImage start="0x000000006AAE0000" end="0x000000006AB86000" path="adobe\AEGPDriver.aex"/>
<binaryImage start="0x000000005A720000" end="0x000000005A74C000" path="adobe\PS Layer Export.aex"/>
<binaryImage start="0x000000005D8E0000" end="0x000000005D917000" path="adobe\PS Layer Import.aex"/>
<binaryImage start="0x000000005E970000" end="0x000000005E979000" path="adobe\EasyEase.aex"/>
<binaryImage start="0x0000000067D00000" end="0x0000000067D0C000" path="adobe\ExpScale.aex"/>
<binaryImage start="0x0000000067D20000" end="0x0000000067D30000" path="adobe\Sequence.aex"/>
<binaryImage start="0x0000000067D40000" end="0x0000000067D49000" path="adobe\TRKeys.aex"/>
<binaryImage start="0x000000006AE70000" end="0x000000006B059000" path="adobe\Cineware_AE_LiveLink.aex"/>
<binaryImage start="0x0000000067D70000" end="0x0000000067D84000" path="adobe\HashIO.aex"/>
<binaryImage start="0x0000000067DA0000" end="0x0000000067DE1000" path="adobe\PNGIO.aex"/>
<binaryImage start="0x000000006AB90000" end="0x000000006ABF9000" path="adobe\Advanced3D.aex"/>
<binaryImage start="0x0000000067E10000" end="0x0000000067E1A000" path="adobe\Standard3D.aex"/>
<binaryImage start="0x0000000074130000" end="0x0000000074229000" path="adobe\AEDynamicLinkServer.aex"/>
<binaryImage start="0x000000006AC00000" end="0x000000006AC3E000" path="adobe\Audio Palette.aex"/>
<binaryImage start="0x000000006ADA0000" end="0x000000006AE07000" path="adobe\Brush Palette.aex"/>
<binaryImage start="0x0000000082FC0000" end="0x0000000083B1A000" path="adobe\Calder.aex"/>
<binaryImage start="0x000000006BD30000" end="0x000000006BDE5000" path="adobe\Character Palette.aex"/>
<binaryImage start="0x000000006AE10000" end="0x000000006AE3D000" path="adobe\Ernst.aex"/>
<binaryImage start="0x000000007FBA0000" end="0x000000007FD18000" path="adobe\ErnstLib.dll"/>
<binaryImage start="0x000000006BDF0000" end="0x000000006BE40000" path="adobe\Info Palette.aex"/>
<binaryImage start="0x0000000073E20000" end="0x0000000073E94000" path="adobe\Paint Palette.aex"/>
<binaryImage start="0x0000000073EA0000" end="0x0000000073F11000" path="adobe\Paragraph Palette.aex"/>
<binaryImage start="0x0000000073F60000" end="0x0000000073FB5000" path="adobe\Properties Palette.aex"/>
<binaryImage start="0x0000000083B20000" end="0x00000000851A4000" path="adobe\Roto Brush.aex"/>
<binaryImage start="0x000000007F8D0000" end="0x000000007F960000" path="adobe\Time Palette.aex"/>
<binaryImage start="0x000000007F960000" end="0x000000007FA3B000" path="adobe\Tool Palette.aex"/>
<binaryImage start="0x0000000073FC0000" end="0x000000007400F000" path="adobe\dvawhatsnewui.dll"/>
<binaryImage start="0x0000000074230000" end="0x0000000074263000" path="adobe\dvawhatsnew.dll"/>
<binaryImage start="0x000000007FA40000" end="0x000000007FAAA000" path="adobe\Tracker Palette.aex"/>
<binaryImage start="0x000000007FAB0000" end="0x000000007FADD000" path="adobe\WorkQueue Palette.aex"/>
<binaryImage start="0x00007FFE3C190000" end="0x00007FFE3D5DA000" path="adobe\mochashapeconverter4ae.aex"/>
<binaryImage start="0x00000000851B0000" end="0x0000000085283000" path="msvcp90.dll"/>
<binaryImage start="0x000000007FAE0000" end="0x000000007FB83000" path="msvcr90.dll"/>
<binaryImage start="0x000000007FE90000" end="0x000000007FF9F000" path="adobe\Anywhere2.aex"/>
<binaryImage start="0x000000007FFA0000" end="0x000000007FFC3000" path="adobe\eaurl.dll"/>
<binaryImage start="0x00007FFEF4BE0000" end="0x00007FFEF4BEB000" path="drprov.dll"/>
<binaryImage start="0x00007FFEEE230000" end="0x00007FFEEE248000" path="ntlanman.dll"/>
<binaryImage start="0x00007FFE7C3E0000" end="0x00007FFE7C3FE000" path="davclnt.dll"/>
<binaryImage start="0x00007FFEE7480000" end="0x00007FFEE748D000" path="davhlpr.dll"/>
<binaryImage start="0x00007FFEF7410000" end="0x00007FFEF7427000" path="wkscli.dll"/>
<binaryImage start="0x00007FFED16C0000" end="0x00007FFED16D2000" path="cscapi.dll"/>
<binaryImage start="0x000000007FD30000" end="0x000000007FDC9000" path="adobe\CEPManager.aex"/>
<binaryImage start="0x00007FFE40C10000" end="0x00007FFE40D1E000" path="adobe\adobe_caps.dll"/>
<binaryImage start="0x00007FFEE36E0000" end="0x00007FFEE3A0B000" path="msi.dll"/>
<binaryImage start="0x00007FFEF0AF0000" end="0x00007FFEF0B01000" path="wbemprox.dll"/>
<binaryImage start="0x00007FFEED500000" end="0x00007FFEED594000" path="wbemcomn.dll"/>
<binaryImage start="0x00007FFEEC5A0000" end="0x00007FFEEC5B4000" path="wbemsvc.dll"/>
<binaryImage start="0x00007FFEEC5C0000" end="0x00007FFEEC6CB000" path="fastprox.dll"/>
<binaryImage start="0x00007FFEE4DF0000" end="0x00007FFEE4E09000" path="amsi.dll"/>
<binaryImage start="0x00007FFEE4C00000" end="0x00007FFEE4C7B000" path="MpOAV.dll"/>
<binaryImage start="0x00007FFE3BED0000" end="0x00007FFE3C186000" path="adobe\IMSLib.dll"/>
<binaryImage start="0x00000000852A0000" end="0x00000000852B9000" path="adobe\LocalizePresets.aex"/>
<binaryImage start="0x00000000852C0000" end="0x000000008532D000" path="adobe\Renoir.aex"/>
<binaryImage start="0x0000000085490000" end="0x00000000854D7000" path="adobe\AnimateImporter.aex"/>
<binaryImage start="0x0000000086040000" end="0x0000000086395000" path="adobe\OpenEXR.aex"/>
<binaryImage start="0x0000000085750000" end="0x000000008582F000" path="adobe\PremiereProImport.aex"/>
<binaryImage start="0x00000000854E0000" end="0x000000008551D000" path="adobe\MediaCoreUI.dll"/>
<binaryImage start="0x0000000086540000" end="0x0000000086C01000" path="adobe\Pro Import AE.aex"/>
<binaryImage start="0x00000000856D0000" end="0x0000000085718000" path="adobe\Align.aex"/>
<binaryImage start="0x0000000085650000" end="0x0000000085670000" path="adobe\Analyzer.aex"/>
<binaryImage start="0x0000000085550000" end="0x000000008561B000" path="adobe\EssentialGraphics.aex"/>
<binaryImage start="0x0000000086480000" end="0x0000000086524000" path="adobe\dvamediaui.dll"/>
<binaryImage start="0x0000000086FE0000" end="0x000000008737D000" path="adobe\Filler.aex"/>
<binaryImage start="0x00007FFE3BCC0000" end="0x00007FFE3BECB000" path="adobe\AdbePM.dll"/>
<binaryImage start="0x00007FFE36B50000" end="0x00007FFE3BCB2000" path="adobe\opencv_world320.dll"/>
<binaryImage start="0x00007FFE573B0000" end="0x00007FFE573D1000" path="avifil32.dll"/>
<binaryImage start="0x00007FFE57450000" end="0x00007FFE57469000" path="avicap32.dll"/>
<binaryImage start="0x00000000863A0000" end="0x00000000863D5000" path="adobe\LumetriScopesPal.aex"/>
<binaryImage start="0x00000000856B0000" end="0x00000000856C5000" path="adobe\MayaImport.aex"/>
<binaryImage start="0x0000000086E10000" end="0x0000000086E5A000" path="adobe\MediaBrowser.aex"/>
<binaryImage start="0x00000000874B0000" end="0x000000008764A000" path="adobe\dvamediabrowser.dll"/>
<binaryImage start="0x0000000086D10000" end="0x0000000086D54000" path="adobe\MetaPal.aex"/>
<binaryImage start="0x0000000086D60000" end="0x0000000086D9D000" path="adobe\MotionSketch.aex"/>
<binaryImage start="0x00000000863F0000" end="0x00000000863FC000" path="adobe\RPFImport.aex"/>
<binaryImage start="0x0000000086DA0000" end="0x0000000086DBA000" path="adobe\RQMonitor.aex"/>
<binaryImage start="0x0000000087650000" end="0x0000000087FB3000" path="adobe\Scripting.aex"/>
<binaryImage start="0x0000000086E60000" end="0x0000000086F8F000" path="adobe\ae_dvascriptui.dll"/>
<binaryImage start="0x0000000088150000" end="0x0000000088218000" path="adobe\dvascriptingES.dll"/>
<binaryImage start="0x00007FFE36A30000" end="0x00007FFE36B50000" path="adobe\microsoft.ai.machinelearning.dll"/>
<binaryImage start="0x00007FFE36380000" end="0x00007FFE36A2A000" path="adobe\onnxruntime.dll"/>
<binaryImage start="0x000000008F270000" end="0x000000008F2C6000" path="adobe\SmartMask.aex"/>
<binaryImage start="0x0000000093AB0000" end="0x0000000093AE2000" path="adobe\Smoother.aex"/>
<binaryImage start="0x0000000093AF0000" end="0x0000000093B2A000" path="adobe\Wiggler.aex"/>
<binaryImage start="0x0000000093B40000" end="0x0000000093D73000" path="adobe\Cineware_AE_Exporter.aex"/>
<binaryImage start="0x0000000093D90000" end="0x0000000093FC3000" path="adobe\Cineware_AE_SceneLayer.aex"/>
<binaryImage start="0x00007FFE4FEA0000" end="0x00007FFE4FEC0000" path="adobe\FastCore.8BX"/>
<binaryImage start="0x00007FFE36260000" end="0x00007FFE36374000" path="adobe\MMXCore.8BX"/>
<binaryImage start="0x00007FFE361B0000" end="0x00007FFE36259000" path="adobe\MultiProcessor Support.8BX"/>
<binaryImage start="0x00007FFE44FC0000" end="0x00007FFE44FFB000" path="adobe\Plugin.dll"/>
<binaryImage start="0x00007FFE33E20000" end="0x00007FFE34C74000" path="adobe\HalideBottlenecks.8BX"/>
<binaryImage start="0x00007FFEA1580000" end="0x00007FFEA1597000" path="NapiNSP.dll"/>
<binaryImage start="0x00007FFEA1560000" end="0x00007FFEA157B000" path="pnrpnsp.dll"/>
<binaryImage start="0x00007FFEF3370000" end="0x00007FFEF3385000" path="wshbth.dll"/>
<binaryImage start="0x00007FFEF46F0000" end="0x00007FFEF470D000" path="nlaapi.dll"/>
<binaryImage start="0x00007FFEA1540000" end="0x00007FFEA1552000" path="winrnr.dll"/>
<binaryImage start="0x00007FFEF02A0000" end="0x00007FFEF0996000" path="D3D10Warp.dll"/>
<binaryImage start="0x00000000A74F0000" end="0x00000000A7695000" path="adobe\Scintilla.DLL"/>
<binaryImage start="0x00007FFEDB760000" end="0x00007FFEDB85B000" path="textinputframework.dll"/>
<binaryImage start="0x00007FFEF5450000" end="0x00007FFEF57AE000" path="CoreUIComponents.dll"/>
<binaryImage start="0x00007FFEF5890000" end="0x00007FFEF5982000" path="CoreMessaging.dll"/>
<binaryImage start="0x00007FFEF49C0000" end="0x00007FFEF4B14000" path="WinTypes.dll"/>
<binaryImage start="0x00007FFED2F10000" end="0x00007FFED2F34000" path="edputil.dll"/>
<binaryImage start="0x0000000023DF0000" end="0x0000000023DFA000" path="adobe\Paint.aex"/>
<binaryImage start="0x000000009F9C0000" end="0x000000009F9F2000" path="adobe\Puppet.aex"/>
<binaryImage start="0x000000009FA00000" end="0x000000009FA1E000" path="adobe\RefineMatte.aex"/>
<binaryImage start="0x00000000A7C40000" end="0x00000000A9215000" path="adobe\RefineMatte2.aex"/>
<binaryImage start="0x00000000A48E0000" end="0x00000000A4B22000" path="adobe\Cineware_AE_Effect.aex"/>
<binaryImage start="0x000000009FDB0000" end="0x000000009FDD7000" path="adobe\PSL_Adjustments.aex"/>
<binaryImage start="0x0000000024100000" end="0x0000000024115000" path="adobe\Box_Blur.aex"/>
<binaryImage start="0x00000000A4B30000" end="0x00000000A4B77000" path="adobe\Levels2.aex"/>
<binaryImage start="0x000000009FDE0000" end="0x000000009FDEC000" path="adobe\Gaussian_Blur_MC.aex"/>
<binaryImage start="0x000000009FE00000" end="0x000000009FE0B000" path="adobe\SolidComposite.aex"/>
<binaryImage start="0x00000000A76A0000" end="0x00000000A76EB000" path="adobe\ImporterWave.prm"/>
<binaryImage start="0x00000000A76F0000" end="0x00000000A7762000" path="adobe\PlatformAudioCodecs.dll"/>
<binaryImage start="0x00007FFE9CC00000" end="0x00007FFE9CD0A000" path="MFReadWrite.dll"/>
<binaryImage start="0x00007FFEE0BA0000" end="0x00007FFEE0C94000" path="MrmCoreR.dll"/>
<binaryImage start="0x00007FFEE7BD0000" end="0x00007FFEE7BE1000" path="windows.staterepositorycore.dll"/>
<binaryImage start="0x00007FFED8390000" end="0x00007FFED83F6000" path="thumbcache.dll"/>
<binaryImage start="0x00007FFEF1D60000" end="0x00007FFEF1E0E000" path="mscms.dll"/>
<binaryImage start="0x00007FFEF1CF0000" end="0x00007FFEF1D01000" path="ColorAdapterClient.dll"/>
</binaryImageSet>
<dumpType>
Mini
</dumpType>
<hbLogSessionDllStatus>
</hbLogSessionDllStatus>
</crash>
</crashreport>
Mar 29, 2021 6:19 PM UTC
as for system specifications please see:
