After Effects not seeing PostScript Fonts
  • April 4, 2018
  • 19 replies
  • 14096 views
Hello all,
After applying the latest update for AE and Premiere this morning, I noticed that neither program lists PostScript Type 1 fonts in their respective font menus. AE CC 2017 still lists (sees) the PostScript  Type 1 fonts correctly. Did I miss a notification regarding dropping support of PostScript  Type 1 fonts or is something amiss? Photoshop, InDesign, and Illustrator still see PostScript  Type 1 fonts. Seems to have only affected the video applications?
System Specs below:
Mac Pro 5,1 (2012)
128 GB RAM
NVIDIA GTX 980
macOS 10.12.6
Font Management via FontExplorer X
Thanks for any help!
Correct answer Tim Kurkoski
We are investigating a problem where After Effects 15.1 is unable to see certain PostScript fonts. This is an unintentional change, and we're still in the discovery phase.
Workarounds in the meantime for this would be to convert the font or obtain an OpenType or TrueType version of it. Failing that, create the text in Photoshop and use the PSD source instead of a native text layer in After Effects. (Yes, that's a bit of a hassle, which would work best if you're not animating the text and don't have to do more editing.) Sorry about the hiccup here.
As Dan stated above and as can be seen here...
How Can We Improve Premiere Pro?
This problem is also affecting Premiere Pro. While I appreciate that there are "workarounds", either by returning to the crude days of creating PSDs of your text or by having to convert every single PostScript font you wish to use, I find it troubling that such a basic function of your software was so simply botched up with a point update. Bugs happen, I can understand this, but this seems to me to be a basic failure of proper software testing before release. This is almost akin to you 'unintentionally' leaving off the pen tool.
I'm no engineer but it seems to me that this PostScript font issue should have been a much higher priority than the list of fixes we saw in AE 15.1.1, especially as it seems to be affecting both of your professional video creation, compositing, and editing applications. However we have been assured in this post by Rameez that they are indeed working on a fix...
Font doesn't appear on my AE but does on my collegue's AE
The only question...is when? Stay tuned indeed...
Seeing problem here in Adobe Premiere Pro v12.1.1 (Build 10) on a Mac running OS X 10.12.6 (Sierra). The update broke a project authored in previous version. I hope Adobe fixes this ASAP.
margaretb42167537
I HAVE SPENT THREE DAYS LOOKING FOR THIS SMALL PIECE OF INFORMATION. After chatting with Adobe for 2+ hours over multiple days, I'm pretty annoyed that this issue even exists.
This one problem has broken ALL of my essential graphics. Every single one of them that I use EVERYDAY. Adobe, HELP US.
In terms of downgrade options, will that fix my essential graphics? Suggestions anyone?
Thanks!
margaretb42167537
Update: I rolled back AE to 15.01.1 and Pr to 12.0.1 and all seems to be in working order for now! If I have any changes, I'll comment!
Thanks to this small corner of the internet for understanding the hell the last three days have been for me!
regsquires
I am glad you got it working. It’s actually surprisingly easy to downgrade which is the one saving grace. Let’s hope they fix this soon
heemanhey
Back to previous version, Thanks a lot Ozzy for posting this.
Adobe > Fail
Same issues here wasted hours trying to figure why After effects was not recognising certain fonts... Hope Adobe fixes it soon. Thank god for the option to revert back to previous version....
Repost of another thread I made:
Transcript from my tech support call regarding problems with the AE update not showing active fonts...
For context, I had attempted another "chat" about an hour prior to this chat, and was instructed to contact Extenis/Suitcase:
This was the second chat session.
Date: 2018-04-12 04:30:26 SGT
To: Everyone
  With the new version few issues going on with the fonts
Date: 2018-04-12 04:30:51 SGT
To: Everyone
  For now I would recommend you to use the previous version
Date: 2018-04-12 04:31:01 SGT
To: Everyone
  Fonts are fine in everything EXCEPT after Effects.
Date: 2018-04-12 04:31:10 SGT
To: Everyone
  yes
Date: 2018-04-12 04:31:20 SGT
To: Everyone
  this issue is only with the after effects
Date: 2018-04-12 04:31:35 SGT
To: Everyone
  I have an identical computer in my office that IS NOT having this problem with after effects.
Date: 2018-04-12 04:33:21 SGT
To: Everyone
Date: 2018-04-12 04:33:58 SGT
To: Everyone
  Yes
Date: 2018-04-12 04:34:05 SGT
To: Everyone
  That is why I am saying that
Date: 2018-04-12 04:34:10 SGT
To: Everyone
  this is an issue
Date: 2018-04-12 04:34:13 SGT
To: Everyone
  going on
Date: 2018-04-12 04:34:24 SGT
To: Everyone
  sometimes it works and sometimes it doesn`t
Date: 2018-04-12 04:34:59 SGT
To: Everyone
  Why did the person I chatted with an hour ago tell me to contact Extensis, and not tell me that this was a known issue with AE?
Date: 2018-04-12 04:37:27 SGT
To: Everyone
Date: 2018-04-12 04:38:00 SGT
To: Everyone
  please allow me 2minutes
Date: 2018-04-12 04:38:07 SGT
To: Everyone
  let me check the previous chat
Date: 2018-04-12 04:40:13 SGT
To: Everyone
  I really apologize for that
Date: 2018-04-12 04:41:14 SGT
To: Everyone
  how do i install the previous version? Which version specifically doesn't have this issue? If I go back to an earlier version, will I be able to open files that I've been working on with the newer version?
Date: 2018-04-12 04:41:40 SGT
To: Everyone
  yes
Date: 2018-04-12 04:42:08 SGT
To: Everyone
  Close the after effects
Date: 2018-04-12 04:42:22 SGT
To: Everyone
  go ahead.
NOTE: Support person at this time performed as "save as" on the open file, and reverted it back to the previous version.
He/she then uninstalled the most recent version of AE, and installed the previous version. I opened the file he had "saved as", and it opened fined, and the type issue was gone.
Date: 2018-04-12 04:47:10 SGT
To: Everyone
  what about other AE files that I saved with the newer version? Files that haven't been "saved as"?
Date: 2018-04-12 04:47:40 SGT
To: Everyone
  it will save everything in that version
Date: 2018-04-12 04:48:37 SGT
To: Everyone
  No, I mean that you did a save as with the file I had opened already before you installed the old version. what about other files that haven't been "saved as"?
Date: 2018-04-12 04:49:02 SGT
To: Everyone
  ok
Date: 2018-04-12 04:49:37 SGT
To: Everyone
  you need to update the application again and save them using the save as option in cc14 version
Date: 2018-04-12 04:49:41 SGT
To: Everyone
  and open them again
Date: 2018-04-12 04:50:05 SGT
To: Everyone
  shouldn't I have known that before you reverted to the older version?
Date: 2018-04-12 04:50:40 SGT
To: Everyone
  I just showed you the steps
Date: 2018-04-12 04:50:49 SGT
To: Everyone
  may I know how many files you have?
NOTE: At this point I opened an AE file that had been most recently saved using the latest (problematic) version. It opened fine in the previous version of AE.
Date: 2018-04-12 04:52:01 SGT
To: Everyone
  The file I just opened had been saved in the most recent version.
Date: 2018-04-12 04:52:46 SGT
To: Everyone
  So, I don't need to "you need to update the application again and save them using the save as option in cc14 version" do I?
NOTE: At this point I opened an another AE file that had been most recently saved using the latest (problematic) version. It opened fine as well
Date: 2018-04-12 04:53:59 SGT
To: Everyone
  This file I just opened was also created/saved in the most recent version, and opened fine.
Date: 2018-04-12 04:54:35 SGT
To: Everyone
  It`s not possible?
Date: 2018-04-12 04:54:54 SGT
To: Everyone
  May I know when you created these files?
Date: 2018-04-12 04:55:02 SGT
To: Everyone
  Look at the modified date for this next file.
Date: 2018-04-12 04:55:43 SGT
To: Everyone
  and when you update your after effects?
Date: 2018-04-12 04:55:44 SGT
To: Everyone
  April 6 it was last saved. With the most recent version.
Date: 2018-04-12 04:57:14 SGT
To: Everyone
  AE was updated prior to April 6. Yet the earlier version still opens the files just fine.
Date: 2018-04-12 04:58:00 SGT
To: Everyone
  ok
Date: 2018-04-12 04:58:55 SGT
To: Everyone
  ok what?
Date: 2018-04-12 04:59:24 SGT
To: Everyone
  please allow me 3-4minutes
Date: 2018-04-12 04:59:29 SGT
To: Everyone
  let me test this on my end
Date: 2018-04-12 05:09:13 SGT
To: Everyone
  It's been 10 minutes
Date: 2018-04-12 05:09:44 SGT
To: Everyone
  I am downgrading my after effects and it is taking a bit time
Date: 2018-04-12 05:09:59 SGT
To: Everyone
  and I really apologize for the long wait time
Date: 2018-04-12 05:10:39 SGT
To: Everyone
  Thank you.
Date: 2018-04-12 05:10:45 SGT
To: Everyone
  Take your time. Just let me know where to send my tech support bill.
Date: 2018-04-12 05:11:00 SGT
To: Everyone
  Yes you do not need to convert the project
Date: 2018-04-12 05:11:24 SGT
To: Everyone
  it will directly open the newer version project in the previous version
Date: 2018-04-12 05:11:38 SGT
To: Everyone
  yep.
Date: 2018-04-12 05:11:55 SGT
To: Everyone
  Anything else I may help you with?
Date: 2018-04-12 05:12:07 SGT
To: Everyone
  What was the first thing you helped me with?
Date: 2018-04-12 05:12:58 SGT
To: Everyone
  Anything else apart from this issue?
Date: 2018-04-12 05:13:09 SGT
To: Everyone
  Seems like I was the one helping you!
Date: 2018-04-12 05:13:17 SGT
To: Everyone
  I'
Date: 2018-04-12 05:13:19 SGT
To: Everyone
  Thank you
Date: 2018-04-12 05:13:50 SGT
To: Everyone
  I'm fine. other than having wasted two hours of my time and now have a headache.
Date: 2018-04-12 05:14:17 SGT
To: Everyone
  bye!
To: Everyone
  Thank you for contacting Adobe. Good Bye.
Date: 2018-04-12 05:14:37 SGT
To: Everyone
  Assume your supervisors will get a copy of this transcript.
Date: 2018-04-12 05:14:49 SGT
To: Everyone
  Amit Chaudhary has stopped viewing the customer's screen.
Thanks Adobe!
Same issue here, thank god for the downgrade option!
regsquires
Just found this out the hard way. I almost never update programs when they come out but I hit the update button today. This is most annoying. Please sort it out soonish. It is a complete pain since you cannot animate fonts with the workaround suggested.
Tim Kurkoski
Adobe Employee
Tim KurkoskiCorrect answer
Adobe Employee
April 4, 2018
sunstreet
Hi. Any advance on this problem? I am trying to use a Postscript font on the latest version of Premiere Pro and it can't be found in the font dropdown even though it's loaded in Font Explorer?
BartonGarrett256  wrote
be more specific about why you won’t recommend one.
I wouldn't recommend a camera or computer hardware manufacturer to you without knowledge of your requirements. For a font converter, the requirements are quite simple: create a valid OTF or TTF file. I would only recommend against solutions that don't meet that requirement, and since I know of none to recommend against, I make no recommendations. You are free to make your own choice here.
If you need assistance with finding a font conversion application, here is a Google search that produces several results on the first page:
https://www.google.com/search?q=convert+postscript+font+to+otf
Among the top hits on that search are Convertio, Everything Fonts, and Online Font Converter.
I should also clarify that I give this advice under the assumption that your license for the font allows you to convert that font.
Regarding the original issue, we are working on a solution for a future update to After Effects.
Tim, thank for the update. Please keep in mind that this exact same issue afflicts Adobe Premiere Pro as well ... and it arose at the same time. Please assure us that the After Effects and Premiere Pro teams are working together on a solution, since it's very likely that they both result from the same bug. Thanks.
