AFX Script Problem Visual Studio Code
  • July 14, 2021
  • 1980 views
i recently started scripting and wrote a script in VS Studio for After Effects, which works fine when i run it from Visual Studio. But when i save it and run the script from After Effect it gives me an error message: "unable to execute at line 20..."
which is a function in my script. everything before gets executed.
I have Variables (a,b)  in my function because i am looking for several Objects meaning CompItem, FootageItem, Folderitem where I'm looking for specific names as a string.
The Function looks like that:
function graballItems(a, b) {
  var proj, curItem, itemTotal, ItemAry;
  proj = app.project;
  itemTotal = proj.numItems;
  ItemAry = new Array();
  for (var i = 1; i <= itemTotal; i++) {
    curItem = proj.item(i);
    if (curItem instanceof b && curItem.name.indexOf(a) !== -1) {
      ItemAry = curItem;
  return ItemAry;
// And i use it like that:
var myCompBeauty = graballItems("CAN_ENDTAG_PRE", CompItem);
But strange though, that it is working from VS Studio.
Does anybody know why the error message appears?
Cheers
Martin
Mathias Moehl
The line "ItemAry = new Array()" suggests that you want to return an array of the found items. But in the line
ItemAry = curItem;
you replace your array with a single item.
If you want to grab all items, you most likely want to do
ItemAry.push(curItem)
instead.
mmueller2Author
First of all, thank you both for your quick reply.
I tried to implement the try and catch statement but without any sucess.
I implemented the push item command but recognized that i only need one item not an array so i changed it to just get the curitem. But still the same error.
Last thing i wanted to try to set an alert line by line to check where the code breaks exactly.
Strange enough the script works like that:
function graballItems (a,b){
    alert("OK");
    var proj,curItem,itemTotal,MyItem;
    proj = app.project;
    for (var i =1i<= itemTotali++){
        if (curItem instanceof b && curItem.name.indexOf(a) !== -1  ){
            MyItem = curItem;
    return MyItem;
But of course i don't want to have an alert 10 times while the script is running.
mmueller2Author
also, grabFirstItem might then be a better name than grabAllItems
thanks for your help, Mathias!
Sorry for the noob question how do i set breakpoints in my script in VS Studio?
Did all the implementations work all fine but still, only when i have this alert line activ.
Without the alert it gives me the Error.
But as said only when i save it. When i launch it from VS Studio directly everything works fine as well.
Ah and the script will always find the specific elements (comps, footage, and folder).
It's a script for a specific Project , but good to have the throw error statement, though.
Justin Taylor-Hyper Brew
Just tested and it works for me after commenting out that line. Try putting it in a try catch and see if you can get any more info on the error.
