Anchor point problems with 'wiggle rotation' effect
  • February 27, 2023
  • 662 views
I know I can use expressions insted of effects for wiggles, but in this case I'd rather just stick with the effect.
But when I rotate, it doesn't seem to correlate with the anchor point. It's as though the anchor point is in the top left corner.
See what happens when I add 'Wiggle Rotate' effect below... if I change the 'anchor point' properties in the effects window it doesnt appear to make any difference?
Correct answer Mylenium
Pre-compose the text to a cropped composition before applying the wiggle and transforms.
Mylenium
Mylenium
MyleniumCorrect answer
Mylenium
