Solemn
best way create a light traveling down a fibre optic path please help
  • May 7, 2021
  • 1059 views
hi guys I am trying to create something similar to this, im hoping someone can give me a bit of advice on the best way to go about this task.
few questions that would help my learning:
1. regarding paths, do i make them in illustrator and import to shapes, or is there way i can replicate the illustrator brushs.
2. Are the paths 3d layers, or would it be better to make them on 3d layers
 thanks in advance
Let's start with the basics. CC 2021 can create tapered lines. Bevil Alpha can simulate a tube, Dashes, Gaps, and Offset can create movement in the lines. Glow and Motion blur can add to the effect. The bottom path was created first, then duplicated and dashes, gaps, and offset were set up, the color changed and the width, then the blend mode was set to add and glow and CC Force Motion blur polished up the look. This took me less than 5 minutes using the rotobezier pen tool on a shape layer. I'm showing you all of the settings including the time - 1800 expression is in Offset to make the dashes move.
That is only one of about 20 ways I can think of to make this happen without any 3rd party plugins. The best workflow depends on your design. AI paths can be copied and pasted. Simple AE paths without brush strokes can be converted to shapes that just have a path. There are lots of ways to create something like your example.
Solemn
SolemnAuthor
hi dont think the video loaded but the graphic im trying to make is the one at the top of this site
https://orao.network/
Jose Panadero
Probably a particle plugin like Trapcode Particular or Stardust could be an option. Another option is to use the Vegas effect (Generate category). With this effect you can create lines based on masks, add segments and animate the evolution parameter to create the animation.
