Bulge adjustment layer doesn't work with position changes
- August 3, 2024
- 1 reply
- 906 views
I'm working on a simple 'fake' globe effect using a bulge adjustment layer with the center parented to a globe composition layer's position. However, when I try to move the globe's position, the bulge does some weird warping and then settles back into place once the globe is done moving.
I have gone through and adjusted the bulge's radius animation path so that it stays within the globe layer throughout the animation. There doesn't seem to be a clear reason for why it's doing this.
I don't think the radius is the cause, as the weird warping occurs when I move the globe in position only. Please help! Thank you!
