Apr 11, 2025 2:49 PM UTC
Difference between Expression Engine and Scripting Engine ? [AE 2025.2 build 131]
In File > Project Settings > Expressions
we have a field named Expressions Engine and we can Select Javascript.
We can then use modern javascript for our expressions.
But When I tried to create a script, method like map, reduce.. on arrays are not recognized.
Does it means scripting is still on LegacyExtendscript ?
Apr 11, 2025 2:56 PM UTC
Yes, ExtendScript has not been updated in a VERY long time.  I think Adobe is making progress in this direction with UXP plugins, but there is a long way to go there.  There are some shims you can find out there for ExtendScript, but the language itself is based on ECMA Script 3 which was released in late 1990s.
Apr 11, 2025 3:18 PM UTC
Thanks for the quick reply, man!!
You might have seen some of my previous posts about UXP for Photoshop...
But let’s be honest — when things take this long, it becomes unacceptable. And the worst part? We never get a proper technical explanation. Just the usual: “work in progress”... then more “work in progress”...
I’m pretty sure every developer feels the same.
It’s like waiting for a train — and every 10 minutes, someone tells you: “work in progress”… and then again… “work in progress”...
I’m from Paris, I know the drill. If the guy announcing the delays keeps repeating the same vague excuse a third or fourth time, trust me — he’s getting chased down the platform by half the station 😂.
Can we please get a real technical breakdown from the community?
WHAT EXACTLY IS TAKING SO LONG? and WHY?
We’re not stupid — we can understand. 🙂
And of course please do not take that personally, it's for the community.
PEACE,
Kasra
