Sep 11, 2024 3:36 PM UTC
HELP! I need a “FxFactory’s Reverse Corner Pin” type solution in After Effects on PC
I have shaky cell phone footage of a security monitor taken at 45° to the right. I need to extract that footage and display it as an ortho rectangle.
I’ve already stabilized the footage with Mocha AE. My next step was to use Reverse Corner Pin until I discovered that it is Mac ONLY and I’m using After Effects on PC.
Is it possible to do with vanilla AE or is there a 3rd party solution that will work with AE on PC or point me to a video explaining the process?
Airweb_AECorrect answer
Sep 11, 2024 7:08 PM UTC
Sep 11, 2024 10:29 PM UTC
THANK YOU, @Airweb_AE for pointing me to @Mike_Abbott! Even 6 years later, This was the EXACT answer I was looking for!
