Enes MUSTAFA
I want to help you with my problem ... I removed it several times ... And the problem is still
  • November 10, 2021
  • 225 views
Nuno Caroco
Check if you´re using third party scripts or a.e plugins that can create some conflict in your system. Those can be the cause. Remove or backup everything.
Uninstall AE ; use Adobe´s Creative Cloud Cleaning tool, and install AE again.
If that does not help contact Adobe Support line or online. Also can be a GPU issue so update your graphic card drivers.
Adobe After Effects ACP & Digital Compositor
nishu_kush
Hi Enes MUSTAFA,
Thanks for reahcing out.
Could you share more details on what's happening? Is After Effects crashing at launch? What are your system specifications (CPU, GPU, RAM, OS).
Please share more details, we're here to help.
Nishu
Enes MUSTAFA
It stops when starting, as shown in the picture
Use the cpu  system
RAM   32 gb
Enes MUSTAFA
WİNDOWS  10
