Not showing up scale,position,rotation, and opacity number
  • September 26, 2020
  • 16845 views
If I want to scale something or turn down the opacity it does not show me the number which I can turn up or down. Anyone know how to fix this?
Check the bottom left corner of your Timeline.
If you open the Learn workspace you can take a guided tour of the UI.
Meme5C57Author
Thanks it worked
OussK
You can also customize your timeline by right click and select the parameter you want to see
