Parenting problem ?? what's going on ? weird results
  • December 26, 2018
  • 5 replies
  • 13639 views
Hi everyone, Did something change in the last updates of After effects? I being using AE for decades... yes decades, since version 3.1 but today I just can't do a simple parenting...
maybe there is a hidden preference somewhere.... this never happened to me.
So layer B is parented to A.
Layer A is in a different position and it has some scale applied, no animation so far. Normal result would be as soon as you parent layer B to layer A any new modification over layer A will be apply also to layer B. Well when I parented the Layer B to layer A it automatically copy the distorsion and position of the layer A instead of remain untouch and move or deform with any new adjustmente over layer A.
??????? what's going on here? Can't believe I'm stucked on something like this
Thanks for your help
IT'S EXPRESSIONS.
And I think it started when they moved to JavaScript.
I find if there are no expressions, the child remains in the same position but if there are expressions it moves. Parent first, expressions second.
And this is because the values update on the child based on the parent, which changes the expression.
This might also have always worked this way but we are all using more expressions now processors are fast enough and the expression engine has joined the 21st century.
Hi. I know this is an old post but probably others like me will come across it because of this behaviour.
I don't know if it is the single cause for this but it happends when I have an expression on position, scale or rotation. That is why you need nulls matching those parameters and then parenting that null to a 'master' null.
Hope this helps future users.
Shift + parent snaps the child layer to the same position as the parent and applies all of the same Layer/Transform properties except opacity.
The sample comp is gone, but I cannot reproduce the error.
Sometimes though,  you pick whip to parent a layer and the layer moves. I would like to know what would cause this. Parenting to an object that has scaled to 0 goes wrong, but if the parent is scaled to 1% before parenting, it works. So maybe the clue is in the number values.  It would be helpful to have a list of circumstances where pickwhipping to a parent (not holding anything else) will still move the child and make the twenty-five year After Effects Vet scream like a Banshee
I have been using After Effects for a few years and now, for the first time, I have encountered it too.
Layer A is the parent, Layer B is the child
Untill now, parenting the general whip parenting didn't change absulut values, but it began to behave as if I liked the "Scale of B to the skale of A" with Alt key...
very wierd, never had to use nulls to parent them, since the general pickwhip was like "from this point forward" kind of parenting and now it changes....
I feel you!
No thanks to all the gaslighter responses as usual, acting like this random and inconsistent behavior from AE is infact normal and predictable, and it's actually somehow our fault for not getting it. I'm sick and tired of these condescending remarks from these ancient forum trolls.
I also have been using AE professionally for over 10 years, am not a total moron, and I'm running into this issue for the first time. I parent layer A to layer B. Layer A scale values should not immediately change from 100% to 2% yet that is what is happening and it is causing all kinds of issues with my scene. That is never ever how general pickwhip parenting has worked. And no I'm not holding the shift key while parenting.
If someone can explain what is actually causing the issue here or perhaps acknowledge it as a bug, please do. If you're going to give some non-answer telling me to calm down or explaining how AE is coded, then don't bother.
I will add - I have never encountered this issue in the past but dragging the pick whip to parent layer A to B preserves the scale of layer A as intended. However if instead of using the pickwhip I select layer B as a parent from layer A's parent dropdown list, I get the immediate scale change of layer A.
In my experience either method usually gives the same result, sometimes one is just more convenient than the other in terms of screen space.
Has anyone else noticed this discrepancy? And does anyone know if there is an intentional but subtle difference between using the pickwhip (from layer name to layer name) vs selecting a parent layer from the drop down list?
Nevermind. I continued to test this theory and I'm getting totally inconsistent results... I don't know what the hell is going on
December 26, 2018
here is an example project.. it seems that rotation is the problem. what why?
Dropbox - parent problem.aep
Maybe a bug? or some weird new preference....?
P.M.B
Not sure what version you're using but the behavior is the same in 15.1.2
I've never encountered this before because I've never used solids in this way.
I either use shape layers or masked solids.
This behavior doesn't happen with either of those workflows.
Instead of un-constraining the scaling & changing  the x & y of solid separately, leave the solid scale alone and apply a mask.  You won't encounter this issue.  Or use shapes.  Or create the solids with desired dimensions to begin with.
Once you scale the solid un-proportionally it messes something up.   If you know for sure this has never been an issue before then file a bug report
~Gutterfish
December 27, 2018
Thanks Gutterfish, the solids I sent was just a quick project as an example, the real project has many layers and it's a logo animation where layers from .ai file are following others layers that has rotation and scale applied they are not only solids.
But yes it seems that the bug is when the scale and rotation are applied together before parenting a layer. To be honest I can't tell if this error was there before or not, it's a pretty common operation so I guess it has to be a new bug I guess everyone will notice a major error like this.
file a bug report to adobe didn't work for me in the past, neither sending them features recommendation so I don't feel very optimist about that. anyway, I guess I will need to do a new workflow for this comp.
Cheers,
