preview with no sound ?
  • August 7, 2019
  • 1197 views
I got sound when i export it but none while doing either ram preview or preview.
sound output is checked
please help
    Correct answer Martin_Ritter
    First make sure that the MXF files have sound embedded.
    Second make sure, that AE can read the sound data (just click on the little arrow in front of "Waveform" to see if there is any).
    Third make sure, that you get sound from some random WAV file.
    You can also check the preferences and see, if audio get's muted whenever playback falls behind realtime (I think the checkbox is labeled as "Mute audio when ...").
    Once you are there, check the audio hardware settings, too.
    Last, or first - as you wish - check the box in preview panel "Cache Before Playback".
    *Martin
    thats the other part
    Martin_Ritter
    Martin_RitterCorrect answer
    *Martin
    Big thanks tyvm
