Problem changing duration of layers/Is there a quicker way of organising their positions?
I seem to having a problem with sorting out the duration of my layers/images. I'm trying to put an animation I've rendered out from 3ds Max into a video animation. I need each frame/layer to be a millisecond. When I selected all the layers I needed, right clicked, and went to Time > Time Stretch, I specified the time I wanted. Now, however, it's not letting me do that. The Stretch Factor is always 0.11111%, but the duration is always 0:00:00:09 and won't change. Not unless I scrub the bar manually, but even then, it sets it to 00:00:00:02 instead. Then if I change it to 00:00:00:01 via the Time Stretch, it sets it correctly. o_O
Also, if I do manage to get all the layers the same length of time, is there a quick way of setting them up? Is there any way I can specify when and where a frame/layer starts? Otherwise, I've got to manually scrub over 100+ frames into their positions.
Thanks
