Yoni34575889derh
Sep 8, 2025 5:38 PM UTC
Problems with color correction with HDR file with Adobe after effects and premeire pro
I tried uploading footage into After Effects and Premiere Pro, but the videos came out way too bright because of HDR. I looked up how to change the color settings, but even after trying those, the footage still doesn’t look close to the original. I need your help finding the right settings so it looks correct. The After Effects version looks the worst. I’m attaching a picture to help you understand.
Sep 8, 2025 6:26 PM UTC
You have to check the color profile from your file and check the gamma by clicking on the "8bpc" button in the project window.
Sep 8, 2025 10:26 PM UTC
Hi Yoni,
Hi, thanks for posting your HDR color question. I’ve flagged it for the product team so they can weigh in soon. Appreciate your patience while we wait for their feedback!
Yoni34575889derh
Sep 10, 2025 6:42 AM UTC
Thank you! I am waiting
