problems with running script :"JSON validation undefined" and then "uneble to execute script...
  • February 8, 2023
  • 4 replies
  • 460 views
downloaded the "Limber" script, when I install it, it makes an error
"JSON validation undefined", then when I click on "ok" it says "unable to execute script at line 2987.null is not an object"
upd: all the boxes are checked
Mathias Moehl
open a support ticket here:
https://aescripts.com/contact/#new-ticket
The aescripts support is usually pretty good 🙂
Mylenium
Standard answer: Check the creator's web site for an updated version. Lately AE seems to become very picky about this stuff and frowns at the slightes bit of "bad" code. Aside from that consider reinstalling AE after deleting the prefs. Perhaps some botched setting or data has snuck in that messes this up.
Mylenium
The problem is that when I had an older version, everything was fine, then when I downloaded a newer version, it all started. not only that, but now when I download an older version (the one that was before), it throws an error. I've already reinstalled the program - it doesn't help.
Dan Ebberts
I'd open a trouble ticket with the vendor. The line number in the error message won't mean anything to anyone else.
