Jan 23, 2024 9:05 PM UTC
Render multiple parts of same composition using script
Hi!
I've been trying to come up with a script that takes information from markers in a composition, to add one or multiple instances of this same comp to Render Queue - the markers should define custom Start and Duration for each render.
I have the following script so far, but I'm having trouble with setting the timeSpanStart and timeSpanDuration (the way I'm entering information seems to be invalid to latest versions of AE):
// Get the active composition
var comp = app.project.activeItem;
// Check if the active item is a composition
if (comp && comp instanceof CompItem) {
  var markers = comp.markerProperty;
  var renderQueue = app.project.renderQueue;
  // Iterate through all markers
  for (var i = 1; i <= markers.numKeys; i++) {
    var marker = markers.keyValue(i);
    // Check if the marker's duration is greater than 0
    if (marker.duration > 0) {
      foundMarkers = true;
      // Set the output file name based on the marker's comment
      var outputName = "export_" + marker.comment + ".mp4";
      // Create a new render queue item
      var renderQueueItem = renderQueue.items.add(comp);
      renderQueueItem.outputModule(1).file = new File(outputName);
      // Set the time span start and duration
      renderQueueItem.timeSpanStart = marker.time;
      renderQueueItem.timeSpanDuration = marker.duration;
  // Show an alert if no duration markers were found
  if (!foundMarkers) {
    alert("No duration markers were found");
} else {
  alert("Please open a composition before running this script.");
alert("Great job! Now go back to editing");
Thanks in advance for any help!
Jan 24, 2024 4:25 AM UTC
It's not:
app.project.activeItem.markerProperty.keyValue(i).time;
but:
app.project.activeItem.markerProperty.keyTime(i);
    var t = markers.keyTime(i);
      renderQueueItem.timeSpanStart = t;
} else {
