Pamplemuss
Swap colors between fill and stroke in After Effects
  • October 3, 2018
  • 3916 views
Bonjour, Is there a keyboard shortcut or a button for swapping colors between fill and stroke in After Effects CC?
Correct answer Dave_LaRonde
Nope, but you can make a solid, eyedropper one of the colors, and then do the color swap on the shape.  If it takes any more than 20 seconds, you're doing it wrong.
Dave_LaRonde
Dave_LaRondeCorrect answer
Κακό ψόφο.
