Steven Tritton
System Requirements for After Effects
  • November 18, 2019
  • 1247 views
Hi there
Can anyone advise if my computer system will run After Effects?
Graphics Card: AMD Radeon HD 7000 Series
100 GB free Hard Disk Space (Can create more if needed)
OS Name Microsoft Windows 10 Home
System Name DESKTOP-AI8UM9S
System Manufacturer Dell Inc.
System Model OptiPlex 9010
System Type x64-based PC
System SKU OptiPlex 9010
Processor Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Dell Inc. A17, 23/12/2013
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 32.0 GB
Available Physical Memory 25.4 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 29.7 GB
Thanks
Steve
John_FX1
Sure, that should run fine.
As long as your system is 64bit meeting the minimum requirements you'll get After Effects running.
https://helpx.adobe.com/after-effects/system-requirements.html
It'll actually run on lower specs but the larger RAM and faster Processor, the happier it will be.
You may just want to disable or reduce the 'Disk Cache' in the preferances as that will soon fill up and slow down your machine.
Best, John w.
Soho Editors - John
Steven Tritton
Thanks John yes it is 64bit and have 32 GB RAM so hopefully all good as I want to pre-pay for the program for the year.
Steve
John_FX1
