Apr 12, 2023 6:55 PM UTC
White solid is not white in OCIO color engine
How can I make a white solid in the OCIO color space? Currently, the color is not white. It looks almost gray. See my attached screenshots. Both whites are #FFFFFF.
Mylenium
Apr 13, 2023 6:02 AM UTC
Hex codes don't mean much. As Rick said already, you have some wrong settings somewhere. since you haven't provided any info about your CM settings we can't tell you more than that.
Mylenium
GawronAuthor
Apr 13, 2023 1:04 PM UTC
Thanks for the quick reply! I'm attaching my project settings. I'm using ACEScg for my working color space because I'm bringing EXR renders in from C4D/Redshift. If I set my working color space to "None". The "Whites" are correct, but all of my renders are wrong. I need to be able to work in ACEScg with my renders and then also be able to comp in graphics with correct "whites".
Thanks!
Apr 12, 2023 10:30 PM UTC
You have a color management mismatch somewhere. Start by checking the Project Settings (Shift + Alt/Option + Ctrl/Cmnd + K)
