Skip more frames than 99 and higher frame rate than 999?
  • October 21, 2021
  • 241 views
I'm working on an insane comp that's intentionally slowmo for 3 hours with many neseted comps, it would be nice to not have to context-shift into a top level time-remapped comp that's only used to preview the inner comp at a much higher framerate/skipped frames. Plus, I assume time-remap encours some cost in preview rendering.
My comp's animated motion is so slow, in order to get the big picture, I need to constantly preview at super high skip. That requires constant switching to the containing comp, and that switch makes the Adobe Cache DB churn for a while instead of just hitting the RAM/cache drive instantly. Feels very sluggish compared to just hitting preview.
egustalAuthor
meant to say time-stretched, not remapped, but same problem either way.
