eslmaxx
Audio does not play in movieclip on first click. It plays on second click.
  • July 5, 2021
  • 212 views
Hi Everybody,
I was editing an animate file I made in 2018.  When I exported it, I found that audio does not play when I click a button, although the animation does play.  When I click it the second time, the audio plays.
I have 6 movieclips on the stage and it is the same with each of them.  When I export the movie and click on any of them, the animation will play but not the sound.  When I click on any of them after that, or I click on the first one a second time, the sound plays.
When I just play the 2018 html file I can click on any of the movie clips and the sound plays with the animation.
The code in each movieclip is
this.ed4.addEventListener("click", fl_ClickToGoToAndPlayFromFrame_31.bind(this));
function fl_ClickToGoToAndPlayFromFrame_31()
this.gotoAndPlay(1);
exportRoot.stopped_.gotoAndStop(0);
exportRoot.missed_.gotoAndStop(0);
exportRoot.walked_.gotoAndStop(0);
exportRoot.wished_.gotoAndStop(0);
exportRoot.punched_.gotoAndStop(0);
I have the audio on the 3rd frame of the movie clip.
Does anyone have any idea what might be happening here?
Thank you in advance!
    kglad
    users must interact with your site before sound can plan. (learn how to use your browser's developer console for debugging.)
    eslmaxx
    eslmaxxAuthor
    It seems like they have to interact twice, though.  And this is a problem that occurs only when I export files, even if I don't edit them at all.  When I run the old file - an exact copy that was exported 2 years ago, the audio plays with the animation on a single click.  So I thought it must be something to do with updates in Animate in the past two years.
    Ok, I'll look into Chrome's developer console for debugging, assuming it is a bug and not what would actually be expected given the most recent version of Animate.
