How to control mouse events with other mouse events Actionscript 3, please help!
  • February 12, 2012
  • 3139 views
I'm working on a virtual guitar simulation project and to be honest my flash skills are very beginner.
Right now all the sounds (78 of them) on my guitar play using the roll_over event but that doesn't give the user much control over what sound is played.
The actionscript im using to play my sounds is this;
for(var i:uint = 0; i < buttonArray.length; i++){
buttonArray.addEventListener(MouseEvent.ROLL_OVER, buttonRolledOver);
//This function stops any sound clip that is playing and
//plays the sound file thats clicked.
function buttonRolledOver(e:MouseEvent):void{
// SoundMixer.stopAll(); -- stops sounds playing when next one is played
if(e.target == buttonArray){
var s:Sound = new Sound();
s.load(new URLRequest(soundArray));
s.play();
What i want to do is only play a sound with the roll_over event when the left click is held down.
I'd very much appreciate some help with that. A friend of mine advised me to use an if statement but I'm not really sure how to implement that.
Thanks!
kglad
first, you should initialize your app by loading all your sounds and store the sound objects in soundArray.  otherwise, that's a major memory hog and sound-start latency will be an issue if that's deployed on the internet.
also, you should be using movieclip buttons or simple buttons with names that make it easy to extract i from buttonArray.  then you can use:
var sc:SoundChannel;
buttonArray.addEventListener(MouseEvent.MOUSE_DOWN, startF);
buttonArray.addEventListener(MouseEvent.MOUSE_UP, stopF);
function startF(e:MouseEvent):void{
sc=soundArray[extractIndexF(e.currentTarget.name)].play();
function stopF(e:MouseEvent):void{
sc.stop();
function extractIndexF(nameS:String):int{
// return index of buttonArray item
Thanks for your reply. Yes i'm using a soundarray which stores all the sounds, here is a snippet of it. I hope this is what you mean.
var soundArray:Array = new Array();
soundArray[0] = 'sounds/01.mp3';
soundArray[1] = 'sounds/1.mp3';
soundArray[2] = 'sounds/2.mp3';
soundArray[3] = 'sounds/3.mp3';
soundArray[4] = 'sounds/4.mp3';
soundArray[5] = 'sounds/5.mp3';
soundArray[6] = 'sounds/6.mp3';
soundArray[7] = 'sounds/7.mp3';
soundArray[8] = 'sounds/8.mp3';
soundArray[9] = 'sounds/9.mp3';
soundArray[10] = 'sounds/10.mp3';
soundArray[11] = 'sounds/11.mp3';
soundArray[12] = 'sounds/12.mp3';
and a code snippet of the button array:
var buttonArray:Array = new Array();
buttonArray[0] = lowe_btn;
buttonArray[1] = lowe1_btn;
buttonArray[2] = lowe2_btn;
buttonArray[3] = lowe3_btn;
buttonArray[4] = lowe4_btn;
buttonArray[5] = lowe5_btn;
buttonArray[6] = lowe6_btn;
buttonArray[7] = lowe7_btn;
buttonArray[8] = lowe8_btn;
buttonArray[9] = lowe9_btn;
buttonArray[10] = lowe10_btn;
buttonArray[11] = lowe11_btn;
buttonArray[12] = lowe12_btn;
Anyway I put that code you posted into my program to replace the code I posted here initially but it comes up with an error referring to that last function which only has a comment on it.
kglad
I took out the line
'soundF();'  which you put after declaring the variables and the error SecurityError: Error #2000: No active security context doesn't show anymore but the sounds still don't play. a friend said the publish settings could be the problem however they're pretty much the same as I had them when i was using the code i originally posted here and the sounds played.
I unchecked export SWC though and the warning 'No libraries were linked as Runtime Shared Libraries (RSLs) because of your publish settings: Export SWC' also dissappeared.
what are the file names of your mp3's?
