Apr 11, 2014 4:09 PM UTC
Need help on a (simple) sound/video problem (As3)
Hi People, after being away from Flash for 10yr. i tried making a simple music thingie but ran into a problem:
so i basically structured it brutally old school with time/frame animation and embedded media.
so: i have 3 frames (with buttons jumping to the sprcific frames)
each frame has embedded Video or Audio (playting on "event x1"
so what i thought i could do was having the button go to frame 17 and play sound
then add a "SoundMixer.stopAll();" at frame 32 to stop the "old" sound from playing
when the next button is called to go to frame 33 and play a new sound.
stupid simple and seemed as the "easiest" (for a newbee) way to do it without
getting into too much actualy code.
Problem remaining: after the SoundMixer.stopAll();
nothing will play (no sound)
so i need to find a way to allow sound to play again, like:
SoundMixer.ok to play whatever sound again();
and yes i know this is a stupid as it gets, no clever and there are 1000 better wats to do it
but i am afraid it is over my head
Ideas?
SCUMSPAWNAuthor
Apr 11, 2014 4:20 PM UTC
can i do something like:
SoundMixer.stop("sound1.mp3")
SoundMixer.stop("sound2.mp3")
instead of the: SoundMixer.stopAll();
or something like: (frameaction)
remove.("sound1.mp3")
...this is driving me crazy, everything in this move works fine except for this last sound thing
kglad
Apr 11, 2014 4:40 PM UTC
no.
should stop all currently playing sounds but stops no sound subsequently started.
SCUMSPAWNAuthor
Apr 11, 2014 5:55 PM UTC
Holy mother of funk!
i removed the eventlistener and 3 lines of code (see the image) that should enable the frame action, and ONLY put the:
SoundMixer.stopAll();  as a frame action before every new sound/video, and it works, for the video too...
a w e s o m e and thanks for leading me on to a simple solution that works... :-)
