Position sprite on edge of polygon
  • December 2, 2016
  • 745 views
Hi all
So, mathematics. This one is to tuff for me. I use this Class: http://snipplr.com/view/67582/as3-drawing-shapes-arc-burst-dashedline-gear-polygon-star-wedge-line/
To draw a polygon. I then want to position a sprite on the edge of that polygon. I would like to define the place on the polygon as a degree, so that 0 and 360 would give me the same result.
I have this script.
package
    import flash.display.MovieClip;
    import flash.display.Graphics;
    import flash.display.Sprite;
    public class Polygon extends MovieClip
        private var marker:Sprite;
        public function Polygon()
            marker = new Sprite();
            addChild(marker);
            marker.graphics.beginFill(0xFF0000, .8);
            marker.graphics.drawCircle(0, 0, 10);
            graphics.lineStyle(3, 0x0074B9);
            positionInPolygon(marker, 400, 300, 5, 200, 0, 20);
            DrawingShapes.drawPolygon(graphics, 400, 300, 5, 200, 0);
        public static function positionInPolygon(target:Sprite, x:Number, y:Number, sides:uint, radius:Number, angle:Number, atAngle:Number):void
            if (sides <= 2)
                throw ArgumentError("DrawingShapes.drawPolygon() - parameter 'sides' needs to be atleast 3");
                return;
            if (sides > 2)
                var step:Number, start:Number, n:Number, dx:Number, dy:Number;
                step = (Math.PI * 2) / sides;
                start = (angle / 180) * Math.PI;
                // Here I can set an integer instead of zero to jump between corners, not what I want though
                target.x = x+Math.cos(start + (step * 0)) * radius;
                target.y = y+Math.sin(start + (step * 0)) * radius;
I need to set target x and y differently. But how?
Let me know if it didn't make sense. I would be graceful for any help.
Jakob Wagner
Correct answer Jakob Wagner 2048
Thank you for taking the time. Unfortunately, they need to be distributed evenly. I have been trying different things over the weekend and ended up with this, taking a radical different approach. It works. Have the feeling a maths expert could do it in a simpler way, though. And it would be cool if I could bevel the corners, which is going to be impossible with this approach.
Not to worry, this will do for now.
Jakob
package
    import flash.geom.Point;
    import flash.events.Event;
        private var numberOfMarkers;
        private var markers:Sprite;
        private var offset:Number;
        private var numberOfSides:int;
        private var polygonAngle:Number;
            numberOfMarkers = 50;
            offset = 0;
            numberOfSides = 3;
            polygonAngle = 0;
            markers = new Sprite();
            addChild(markers);
            for(var i:int=0;i<numberOfMarkers;i++)
                var marker:Sprite = new Sprite();
                markers.addChild(marker);
                marker.graphics.drawCircle(0, 0, 7);
                positionInPolygon(marker, 400, 300, numberOfSides, 200, polygonAngle, 360/numberOfMarkers*i);
            addEventListener(Event.ENTER_FRAME, thisEnterFrame);
        private function thisEnterFrame(e:Event)
            offset++;
            polygonAngle--;
                var marker:Sprite = markers.getChildAt(i) as Sprite;
                positionInPolygon(marker, 400, 300, numberOfSides, 200, polygonAngle, 360/numberOfMarkers*i+offset);
        public function positionInPolygon(target:Sprite, x:Number, y:Number, sides:uint, radius:Number, angle:Number, atAngle:Number):void
            if (sides <= 2)
                return;
            if (sides > 2)
                var points:Array = [];
                var step:Number, start:Number, dx:Number, dy:Number;
                points[0] = new Point(x + (Math.cos(start) * radius), y - (Math.sin(start) * radius));
                for (var i:int=1;i<=sides;++i)
                    dx = x + Math.cos(start + (step * i)) * radius;
                    dy = y - Math.sin(start + (step * i)) * radius;
                    points = new Point(dx, dy);
                atAngle = atAngle%360;
                // the length of each side
                var sideLength:Number = 2*radius*Math.sin(Math.PI/sides);
                // the length of all sides combined
                var totalLength:Number = sideLength*sides;
                // distance from point 0 if all sides where put in one long line
                var distanceFromStart:Number = totalLength*atAngle/360;
                // index of the start point
                var startPoint:int = Math.floor(distanceFromStart/sideLength);
                // index of the end point
                var endPoint:int = startPoint==sides-1?0:startPoint+1;
                // distance from the start point
                var distanceFromStartPoint:Number = distanceFromStart-(sideLength*startPoint);
                // difference between the to points on x, creating the side a in a right angled triangle
                var a:Number = points[startPoint].x-points[endPoint].x;
                // difference between the to points on y, creating the side b in a right angled triangle
                var b:Number = points[startPoint].y-points[endPoint].y;
                // the angle A, opposite of side a
                var A:Number = Math.atan(a/b);
                // the new side a based on angle A and distanceFromStartPoint
                var na:Number = Math.sin(A)*distanceFromStartPoint*(b<0?1:-1);
                // the new side b based on angle A and distanceFromStartPoint
                var nb:Number = Math.cos(A)*distanceFromStartPoint*(b<0?1:-1);
                target.x = points[startPoint].x+na;
                target.y = points[startPoint].y+nb;
Jakob Wagner 2048AuthorCorrect answer
Jakob
package
            offset = 0;
            numberOfSides = 3;
            polygonAngle = 0;
            addChild(markers);
            offset++;
            polygonAngle--;
            if (sides <= 2)
                return;
            if (sides > 2)
kglad
we need to see DrawingShapes.drawPolygon
It's on the link, but I put it below here also.
public static function drawPolygon(target:Graphics, x:Number, y:Number, sides:uint, radius:Number, angle:Number=0):void
            // check that sides is sufficient to build
            if (sides <= 2)
                return;
            if (sides > 2)
                // init vars
                // calculate span of sides
                // calculate starting angle in radians
                target.moveTo(x + (Math.cos(start) * radius), y - (Math.sin(start) * radius));
                // draw the polygon
                for (n = 1; n <= sides; ++n)
                    dx = x + Math.cos(start + (step * n)) * radius;
                    dy = y - Math.sin(start + (step * n)) * radius;
                    target.lineTo(dx, dy);
kglad
what's wrong with your marker?
