Oct 7, 2023 3:19 PM UTC
Rigged body parts not showing onion skin
basically, I rotated the torso slightly on every frame, but only the torso shows onion skin, although everything else is linked to it through armature/rigging. I need all body parts to show onion skin, please help.
Mario_CR
Oct 7, 2023 4:21 PM UTC
Are the other layers locked? If so, unlock them or the onion skin won't show up for them.
zqilAuthor
Oct 8, 2023 7:01 AM UTC
nope.
Also, I realized that when I rotated the body, only the body gets keyframed. Everything else, although moved, didnt register as a different image. But when I update it by moving/rotating the body parts, they instantly register as a different frame and shows onion skin, (even if I move them to the exact same place).I need them to auto keyframe as well, so that I can see onionskin
n. tilcheff
Oct 8, 2023 10:55 AM UTC
It will be good if you could post a screen recording, so that others can see your setup and what exactly you are doing. In this way there is a much better chance that someone would be able to guide you.
Nick - Character Designer and Animator, Flash user since 1998 | Member of the Flanimate Power Tools team - extensions for character animation
