Wes Duenkel
Nov 21, 2022 5:10 PM UTC
Bug: Right click requires repeated right click to work in panel that's inactive
Bug: Right click requires repeated right click to work in panel that's inactive. This is a new issue with Bridge 2023 (13.0). Watch the attahed video. This is annoying and problematic.
Rahul Saraogi
Jan 12, 2023 4:54 AM UTC
This issue has been fixed in the latest version of Bridge 13.0.2.636. Could you please try it and confirm if that resolves the issue for you? There are more functional and stability issues fixed in this version. Please refer to the following link to know more.
https://helpx.adobe.com/bridge/kb/fixed-issues.html
Bridge Team
PECourtejoie
Jan 11, 2023 10:20 PM UTC
Hi everyone! good news: the fixed from the beta have been implemented in the main build: download and update Brdige to 13.0.2 from your Creative Cloud application: https://helpx.adobe.com/bridge/kb/fixed-issues.html
Mohit Goyal
Dec 22, 2022 7:28 PM UTC
Hi all,
We're happy to announce the release of Adobe Bridge Beta (13.0.2.630). This update includes the fix for this issue. Also, this Beta release includes several bug fixes done in the 13.0.1 public release. For details, see Fixed issues.
Steps to install/update
Install: Go to the Creative Cloud desktop app and select Beta apps in the left sidebar of the Apps panel. Then select install for your beta app.
Update: Go to the Creative Cloud desktop app, click on Update in the left sidebar of the Apps panel and Check for updates. Then click update for your beta app.
Let us know if this Beta release resolves the problem for those affected, and share your feedback.
Mohit
gary_sc
Nov 21, 2022 5:31 PM UTC
Hi @Wes Duenkel
I'm not fully sure if this is a bug or an application/OS dynamic. Let me explain.
On the Mac, if you have two applications or two folders side-by-side, and you are alternating between the two, first you have to click to let the OS or application know that "Hey, I'm talking to YOU now," then do what you need to do. From what I'm observing here in Bridge, it's very similar — but not consistent. And that is curious but not horrific. I have to admit that a user, probably as long as you (since Bridge. v. 1),
As I was testing this, back and forth between any kind of panel, in each case, the first click was to let the application know I was now working with "THAT" Panel, and then I did what I wanted to do.
I'm not sure that this is a bug, but I cannot speak with authority since I've not noticed a change, and you say you have noticed a change.
Adobe is reading all of these forum threads, and they will note if this is an issue or not. Sorry.
Wes Duenkel
Nov 21, 2022 6:22 PM UTC
This is a "new" behavior. If it's a byproduct of the panel behavior, it's a problem. Here is how the previous version of Bridge worked. Notice no repeated right clicks are required:
gary_sc
Nov 21, 2022 6:38 PM UTC
Hi @Wes Duenkel
OK, thanks for that video. What's interesting is that when you r-click on the "header" of a Panel, the r-click options show up immediately. But, when you r-click on the contents, that requires a "get attention" click, and then the r-click works as you'd expect.
I suspect that this is a "cause-effect" of the multi-Content Panel dynamic. If so, this may stay and not be fixable. But for that, I'm guessing.
