Aug 18, 2026 6:23 AM UTC
On Friday I was able to use camera raw inside bridge and PS, today I cannot turn on GPU ACCELERATION. I have an NVIDIA rtx 5080, and should have zero issues. I need a fix. Please.
Is anyone else having issues with Camera Rawcafter the lastest update on 8/15/26?
    Aug 31, 2026 5:27 AM UTC
    It's a last resort, but please give it a try.
    ​​​​​​​Switched from Camera Raw 18.5 to 14.5
    Erik Bloodaxe
    Aug 18, 2026 12:13 PM UTC
    You might read through this article:
    https://helpx.adobe.com/uk/camera-raw/kb/acr-gpu-faq.html#troubleshoot-acr
    The section entitled "GPU troubleshooting steps for Camera Raw and Lightroom" is relevant. In that section, subsection 7 is worth investigation as I know that the presence of the files TempDisableGPU3 or TempDisableGPU2 have been an issue for many users.
    Aug 27, 2026 5:02 PM UTC
    deleting those temp files no longer solves the issue anymore, its an old fix
    Erik Bloodaxe
    Aug 18, 2026 7:01 AM UTC
    How are you trying to turn on GPU acceleration and what happens when you do? Which CPU do you have and does it have onboard graphics? If so, disable it in Device Manager.
    Aug 18, 2026 11:41 AM UTC
    In both PS and Bridge, edit-camera raw preferences-performance…
    I did disable the onboard graphics
    I have an RTX 5080
    Cpu is amd 9950XD
