Feb 2, 2017 10:13 AM UTC
Small, but irritating problem going from Bridge to Camera Raw
I have Photoshop CS6 on my pc. Clicking on a raw photo in Bridge to continue in Camera Raw 9.1.1 for editing the photo I don't get the full screen Camera Raw. So I have to click on the double arrow above on the right side. But the full screen version does not have the possibility Open, Cancel, Ready right side below, so after editing I have to go back to the smaller screen version of Camera Raw and then I can open to Photoshop.
Someone knows how I can get directly the full screen going from Bridge to Camera Raw, included the possibilities of Open, Cancel and Ready?
Thank you for your help,
Jan Boersma
the Netherlands
Randy Hufford
Feb 3, 2017 4:47 AM UTC
It might also be a screen resolution issue, do you have a multiple screen setup? It sounds as if when you go into large viewing it is cropping off bottom of window do to screen resolution.
Feb 3, 2017 11:57 AM UTC
Op 3-2-2017 om 05:47 schreef Randy Hufford:
created by Randy Hufford
<https://forums.adobe.com/people/Randy+Hufford> in /Bridge General
Discussion/ - View the full discussion
<https://forums.adobe.com/message/9306618#9306618>
Randy Hufford
Feb 3, 2017 4:41 AM UTC
Did you try highlighting the image than clicking on the iris icon? see screen capture.
Feb 3, 2017 11:53 AM UTC
Op 3-2-2017 om 05:42 schreef Randy Hufford:
<https://forums.adobe.com/message/9306616#9306616>
