sarahjbc
Dec 2, 2022 5:09 PM UTC
Body tracker won't work for arms
I am a newbie! I am having trouble getting body tracker to work for arms. I have been experimenting with the included puppets and a couple from graphicmama. When I look at the rigging, it looks like it should work. When I calibrate, I see the nodes, but nothing happens with the arms. The character follows my head and my mouth, it also leans and follows my body...just nothing with the arms. They are draggable...but, I'm lost as to what to do for body tracking. Any advice.... if someone has a character that they know works, I"d love to try it... because I'm not exactly sure where the problem lies.
TheOriginalGC
Dec 2, 2022 6:09 PM UTC
There was a bug with the body tracking limbs in a previous build. Are you using the latest update?
sarahjbc
sarahjbcAuthor
Dec 3, 2022 9:29 PM UTC
Oh, I will double check....
Cherie2450573608fr
Dec 2, 2022 5:29 PM UTC
Do you have body tracker enabled? Under the camera there is a little man, make sure he is lit up blue for body tracker to work. Other than that, not sure what could be causing it.
sarahjbc
sarahjbcAuthor
Dec 3, 2022 9:30 PM UTC
It is definitely enabled. I can see the nodes on my arms... just nothing happens.
