Body tracking requires a puppet with an armed (active) and enabled body behavior
  • November 14, 2022
  • 3359 views
Hello Friend ,
I'm quite new to adobe Character animator software (Ch),
https://pages.adobe.com/character/en/puppet-maker
on this page there is one puppet - fuzzy . i create a scene for this puppet and after that click on body tracking icon (a icon like body,near calibrate button). as soon as I click this I'm getting this error - "Body tracking requires a puppet with an armed (active) and enabled body behaviour"
How can I fix this problem.How can I activate this puppet to record movment as per body tracking captured via camera.
Correct answer TheOriginalGC
You need to simply add the behavior to your puppet's rigging. Go to rigging and click on the behavior column on the root of your puppet and add "body" from the menu. Let us know if that helps.
TheOriginalGC
TheOriginalGCCommunity ExpertCorrect answer
