paulm18875445
Sep 25, 2021 10:36 PM UTC
Body tracking requires a puppet with an armed (active) and enabled body behaviour - CH Beta
Hi there Adobe Community
I have seen the demo video of this Beta version of CH and subsequently downloaded it, and was looking forwarded to getting my puppet to do some funky dance moves (ha ha) using my Son's Band.
I should say that I am new to CH, I have searched for an answer to this question on the web and on the forums but failed to find and answer.
Would one of you clever people kindly point me in the right direction?
Thanks
Newby
    Adobe Employee
    Oct 13, 2021 10:31 PM UTC
    To use body tracking you need to have a puppet on the stage that implements the Body Tracking behavior.
    To find example puppets with Body Tracking simply click the Home icon in Character Animator and hover over the sample puppet descriptions.   Clicking on a Body Tracking enabled puppet there will take you to the Ch Stage with that puppet.  You should now be able to enable body tracking.
    Hope that helps!
    -G.
    Jan 30, 2023 2:40 AM UTC
    Can you enable body tracking on characters made from scratch?
    TheOriginalGC
    Jan 30, 2023 1:43 PM UTC
    Yes, add the "Body" behavior to the root folder of the puppet.
    John T Smith
    Sep 25, 2021 10:44 PM UTC
    What is CH?
    You need to provide the full name of the program so a Moderator may move this to the correct forum
    Also, for a beta version, you may need to find a support/report link where you found the program
    paulm18875445
    Oct 3, 2021 9:33 PM UTC
    Thanks
    CH = Character Animation
