Jun 12, 2022 2:12 AM UTC
Body turns opposite direction of head HEAD & BODY TURNER
Using "Ninja" puppet as my guide, I attemted to set up head and body turns for my puppet. Everything appears to be tagged correctly, yet my body still refuses to turn in sync.I need this puppet to be able to move as smooth as possible so I can track movements for a music video. Any help would be appreciated, I'm like 11 hours in trying to troubleshoot this.
Eli-jah
Jun 12, 2022 9:21 PM UTC
If you want more movement you should restructure to
Head
- Right Profile
- Right Quarter
- Frontal
- Left Profile
Body
- Right Profile
- Right Quarter
- Frontal
- Left Profile
Make sure the head and bodies are tagged using the faces in the properties.
  and give the face and body separate Head and Body turners
The head and body should be able to rotate independently of each other while tracking
Jun 12, 2022 10:22 PM UTC
Gonna give that a try now, I'll let you know how it works out. Thanks! Also does the Head and Body Turner need to be added to the main puppet as well?
