jimmyw3876728
Mar 1, 2019 2:28 AM UTC
CC Project works fine, when export some parts not saving in the rec of project.
I have noticed a few times, when I save a scene in CC, and export it into PR, some parts of the projects from CC does not save (via triggers), but if you look at your project in CC, its loading fine. I have used PNG, Media player, and direct link, has anyone noticed this before??
    alank99101739
    Mar 2, 2019 5:24 AM UTC
    Puppets have properties, and then takes (recordings can override them). But there is also the puppet default. I was wondering if you were changing it in different contexts without realizing it.
    alank99101739
    Mar 1, 2019 3:20 AM UTC
    Do you mean Animate CC or Character Animator? They are different products - I am wondering if you are in the wrong forum.
    jimmyw3876728
    Mar 1, 2019 1:39 PM UTC
    sorry, I mean 'Character Animator'
