alexoner
Characters' Body Disappeared
  • May 11, 2022
  • 598 views
My characters' body appears in the rigging window but in the scene it's completely gone. Any help would be great.
Correct answer TheOriginalGC
In cases like this, it's often that the part hasn't disappeared, but moved out of visible range. Did you recently make adjustments to the original art? If so, you'll need to zoom out until you can find the part and move it back into alignment.
I am also having this issue. The body disapears. I did altar my art and checked to see if it moved out of visible range but it is not there either. Any help will be appreciated.
TheOriginalGC
Could you post a screenshot of the puppet's hierarchy in rigging?
TheOriginalGC
TheOriginalGCCommunity ExpertCorrect answer
