PintoSixty
Mar 10, 2017 8:36 PM UTC
Draggable handles move all body parts simultaneously
I have created sticks and draggable handles in my character's arms and legs.  They are warp-independent body parts.  However, when I drag an arm handle, for instance, all body parts move.  It is the same for any handle on any body part.  No matter which one I choose to drag, all body parts with draggable handles react together.  Why?  I'm stumped.
Also, the character's feet are fixed, but there is a slight drift when moving.  Shouldn't they be perfectly still?
.PSD and .chproj files available on request.
PintoSixty
Mar 11, 2017 12:29 AM UTC
Duh ... I reviewed the tutorial and found all of your suggestions and techniques as you state here.  Sorry for my ignorance and lack of attention.  The only problem I'm having now is that, if I delete all sticks and handles from the legs, then highlight the body to place fixed handles on the feet of the legs, the feet don't stay firmly planted.  They still drift a little bit when I move the head.  (Also, is it a bad idea to have fixed handles on the feet AND sticks and drag handles as well on the legs?)
oksamurai
Mar 11, 2017 12:32 AM UTC
Yes - you either want your limbs fixed or draggable - doing both is going to cause warping issues most likely.
Fixed handles on either +Character or Body should work - they may have slightly different effects depending on your character structure.
PintoSixty
Mar 10, 2017 11:55 PM UTC
Wait ... (LOL) ... what I meant to explain is that, in your "Make first character" tutorial, you told us to highlight the entire character before applying the fixed handles for the feet, not the body.  Was there a tut that updated this procedure?
PintoSixty
Mar 10, 2017 11:49 PM UTC
Wait ... I see what you mean about the fixed handles.  I had placed them in order to keep the feet planted in the scene.  Then, I added sticks and draggable handles in order to play with a walk cycle via one of your tutorials.  I forgot to delete the fixed handles before applying the armatures to the legs.  Is this why the feet were drifting a little bit when I moved the head, instead of being firmly planted in place?  Btw, I used the fixed handle for the feet technique and the behavior mods for drag handles by following your "Making Your First Character" tutorial.  What did I miss?  (Thank you for your quick replies today!)
PintoSixty
Mar 10, 2017 11:33 PM UTC
So take the + designation off the character's name when building in Photoshop or Illustrator?  In that way the default dragger behavior won't appear when importing in ChAn?  In that way, I can assign behaviors to individual armatures? And I'm not quite catching the fixed handles on the body group recommendation.  Is this in one of your tutorials?
oksamurai
Mar 10, 2017 8:42 PM UTC
To me this sounds like you have something forcing the mesh to be a rectangle, like a background image. Do you have a white background or anything like that at the bottom? If so delete it.
Otherwise, yes please - share your File > Export > Puppet file.
PintoSixty
Mar 10, 2017 8:54 PM UTC
