wasy350
Aug 22, 2018 8:54 PM UTC
Head to body connection issues
The head moves with camera however when it moves there is a gap between body and head. My question is how do I get the head to stay connected to body yet still have movement.
    alank99101739
    alank99101739Correct answer
    Aug 22, 2018 10:09 PM UTC
    There is a face property of head position strength. i often change from 100% to 0%.
    alank99101739
    wasy350
    wasy350Author
    Aug 23, 2018 8:12 PM UTC
    Also one more issue with head turn - when I(character) blink the head turns. Why does the head turn when blinking?
    alank99101739
    Aug 23, 2018 8:36 PM UTC
    Where is the blink behavior? If you have it above the head turner it is probably finding one particular blink layer and forcing it to use that. If that is the case, the solution would be to put a blink behavor on each head profile, to ensure the autoblink finds the blink layer in the current head.
