Hello, I have problem with the Character Animator, can somebody help to see what is the problem?
  • May 31, 2023
  • 676 views
kglad
save to a local drive.
<moved from download&install>
Sorry, can I need a more clear explanation?
Is it in the local drive already?
kglad
hmm what do you mean about it? I got this account from my school, I think I am not the admin, just the customer.
then you probably don't have access to adobe support directly.  you're supposed to contact your plan administrator, but they're unlikely to help you with your computer problem whereas adobe support would help you.
