Help with Mouth Rigging
  • March 11, 2024
  • 336 views
Hi! Need help with mouth rigging, I followed some videos online and uploaded the starter mouth pack to my character and it seems like I have everything correct in photoshop. When I upload to character animator it seems to have the values that indicate it recognizes the mouth but when I talk it doesn't mimic my movements, not sure what is going on because I'm still new at this. Any help or tips appreciated!
TheOriginalGC
The mouth set you're using has some "in-between" layers on the Aa, Uh, and W-Oo shapes. Those shapes need to be rigged by adding the Cycle Layers behavior as shown:
I added Cycle Layers but the mouth just stays at neutral, I tried to record audio and the mouth just stayed the same. I just copied and pasted it the mouth pack to my character.
TheOriginalGC
Everything looks correct in the image you've posted. You say you're recording audio. Does it play back and you're just not getting any visemes? Would it be possible to share the puppet (export the puppet and upload it to a file-sharing service like Google Drive or Drop Box) so that we could take a look at it?
