Midi Akai Apc Mini Sliders problem
  • February 4, 2019
  • 908 views
Hi everyone,
I´m so noob using this program but i tried to do some animations with Ch. Is very good this program but i have a question.
I have the Akai Apc Mini Midi Keyboard:
https://www.google.com/search?q=akai+apc+mini+software&rlz=1C1CHBF_esES832ES832&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjv5…
With this midi keyboard i can use the triggers with the square buttons so easy, but when i try use the sliders with the Character Animator doesn´t work.
I don´t know if Character animator has a programable editor of buttons for Midi or exist another software compatible with my Akai Apc.
Many thanks,
David M.
Hi guys,
Thank you to everyone. The problem was the drivers but now the sliders work correctly.
David M
alank99101739
I just wanted to confirm I use sliders to change X and Y position successfully. Are you sure the sliders are generating midi events? I assume you are using the control panel to assign the control events to the right sliders? (I will admit I was doing it the funky way - I have a VR controller generating the MIDI control events so I can wave my hand around to control the puppet‘S hand.)
mre8
Can you describe how you are trying to use the slider? What parameter are you trying to control?
Also, no, there is no midi editor in CH (midi channel etc.).
Hi mre8,
I'm trying use the sliders in a animation frame by frame (named 1 to 7 and another one default in the same folder) and I'm trying to use in a movement to change the x ans y position too and doesn't work neither
Character animator only recognize the buttons because appears press button Midi.
mre8
I just gave this a go with the Behringer X-Touch controller. Both functions worked fine... moving x position and layer picker index at the same time and separately with the fader.
I have had weird midi issues with Akai controllers before. Sometimes, a pad or slider is not sending the message I would expect. I would get some software that monitors incoming midi information to find out what message that slider is sending. Problem is most likely there.
Using Mac or Windows?
