ameliarrw
Feb 13, 2021 8:30 PM UTC
Need head and body to move with legs
I have a puppet that I want to do a "squat" action. I'm not sure if I've rigged it incorrectly, but currently I've only managed to animate the legs "squatting" with the head and body staying static. How can I make the head/body move with the legs without keyframing the actual position of the character?
For a bit more context, the character isn't human and so the anatomy is a bit complicated, which is easily where I could have gone wrong.
k_oshiro
k_oshiroCorrect answer
Feb 15, 2021 11:44 AM UTC
Instead of adding a new handle and adding a drag tag, try selecting the origin and adding a tag there.
If that doesn't work, export your puppet and share it on Dropbox or Google Drive.
If you take a closer look, you may find the cause.
Thank you .
k_oshiro(AdobeCommunityExpert)
ameliarrw
ameliarrwAuthor
Feb 15, 2021 11:52 AM UTC
That did it! Thank you so much for the help 🙂
k_oshiro
k_oshiroCommunity ExpertCorrect answer
Thank you .
k_oshiro
Feb 15, 2021 3:18 AM UTC
I'm not very good at English so I'm afraid I'm not understanding your question correctly.
Add a dragger behavior around the waist of the main layer.
Drag the waist of the puppet in record mode or stream mode.
You can make the puppet squat without hitting keyframes.
However, if your puppet is not a human puppet, it may not work the same way.
I've uploaded a sample puppet to Dropbox.
https://www.dropbox.com/s/4pep7vw75hppvqa/dragger_sample.puppet?dl=0
I've uploaded an instructional video to YouTube, in Japanese.
https://youtu.be/U72g4W4MYl8
Thank you.
ameliarrw
ameliarrwAuthor
Feb 15, 2021 11:03 AM UTC
No worries, your English is great! This definitely makes sense, but I think I have something set up incorrectly in my puppet. I've attached a screen recording of the issue if you're able to help in any way? I didn't set up the original rig, so I don't fully understand everything on the puppet, I'm afraid - it might be something really obvious!
