Jan 24, 2023 7:36 PM UTC
Problems rigging character with body turns
I have a character with both head and body turns. With the following structure:
And the following behaviours:
The limb IK behaviour does not work properly. The feet slide around.
Any suggestions on how to rig and apply behaviours?
TheOriginalGC
Jan 24, 2023 9:48 PM UTC
Try moving your Limb IK behavior from each of the views to the Caveman root folder. As far as the feet go, is your character meant to walk or use the motion library? If not, add a stick across the feet and make it fixed.
jbsthdAuthor
Jan 24, 2023 9:59 PM UTC
The views are correct and the head and body turner behaviours are working correctly. It's just the feet that slide around. Here is the leg rigging:
jbsthdAuthor
Jan 24, 2023 10:07 PM UTC
I've put the LimbIK on the root folder:
It seems to be seeing the tags.
I notice the nionja sample you have has the heads and bodies inside the views. Is that a better structure?
Adobe Employee
Jan 24, 2023 9:18 PM UTC
Can you share a link to your puppet on cloud storage like Google Drive/Dropbox/Creative Cloud?
It is almost impossible to help without the puppet. If sharing just screenshots, please include more images with layers including all body tag placements and all behavior parameters.
Nevertheless, here are my random guesses:
  • Any missing body tags?
  • Is Limb IK properly picking up body tags?
  • Are view tags properly set?
  • Are legs properly made independent (crowned)?
  • Are there any body tags on the origin handles?
  • Is Limb IK set to "Arms and Legs," not "Arms only"?
jbsthdAuthor
Jan 24, 2023 9:39 PM UTC
Sorry, not able to provide puppet.
  • Any missing body tags? I think you can see where the body tags are from the iamge provided
  • Is Limb IK properly picking up body tags? not sure how to test this
  • Are view tags properly set? Don't know what a "view" tag is
  • Are legs properly made independent (crowned)? yes
  • Are there any body tags on the origin handles? No
Adobe Employee
Jan 24, 2023 9:53 PM UTC
The screenshot is surely not showing legs. Are you sure you have left/right knees and heels?
Please do show as many screenshots of many layers and behavior parameters as possible, otherwise, we cannot help.
View tag (see where the red rectangle is):
To check the tags that Limb IK is picking up:
If you see 0 next to Left/Right Knee and Heels, then Limb IK is not seeing leg tags and will not work on the legs.
