Help me to get to bottom of my web designing color management work flow gremlins! PSCS3
Hi all I have been designing fairly high quality webpages now for a number of years but have always been a little uncertain about my own exact color management setup.
I'm running a Dell 2407WFP-HC monitor (1920X1200 resolution/highest 32bit color windows setup) on a Geforce 8600GT video card.
ICC Profile loaded is the default monitor Dell 2407WFP-HC (file name 2407WFPHC.icm) and I have run Adobe Gamma but found it to be fairly even to the default profile so have just left the gamma as the default.
Now in the past I have been designing webpages using the RGB Adobe 1998 (knowing I should really be in SRGB IEC61966-2.1) RGB color space simply because when I am designing on the screen, once I output the graphic via the Save For Web command (in gif/jpg/png) the final image that appears inside the browser (IE, FF, Safari) appears close to what was shown back on my Photoshop CS3 screen. Where as if I design in the SRGB IEC61966-2.1 RGB color space the final image I see in the browser is not what I see back in the Photoshop CS3 screen. (The final image in the browser appears a lot more vivid and bright compared to the Photoshop screen where the design and colors feel duller and faded).
If someone could please explain what is going on here. The actual final result in the browser comparing both images back to back (one in Adobe 1998 and one in SRGB) after using the save for web command is almost exact. And when testing on other machines the colors and pretty well spot on how I like them to appear.
Could anyone could please exlain what his phenomina I am experiencing and the best way to go about correcting it would be greatly appreciated. I'd love to be able to design in the SRGB color space but for this reason it makes it hard.
A few questions, am I the only one that does design in Adobe 1998 for webpages? Also does the Save For Web command convert images into the SRGB color space if they are not already in that color space?
Any help would be great
