"There is a problem with synchronisation" And nothing can fix it?
  • May 25, 2023
  • 547 views
I've had CC for a month now and have not been able to synchronise my files. None of the files in my CC folder will sync to the cloud and it reads "0 out of 0 bytes used". Checked every resource and none of the issues exactly describe the issue I have. (screenshot in Dutch)
kglad
these are the first steps in fixing the problem:
move all the files in your local sync folder to another location (leaving your sync folder empty).
reset the cc desktop app by making sure it's in the foreground, then press:
Win: Ctrl + Alt + R
Mac: Cmd + Opt + R
any problem?
Thank you for your reply/time i've tried this before. Did it again now and still no changes. It just starts loading on startup and after a few seconds, the same error as before!
repair per https://helpx.adobe.com/download-install/kb/creative-cloud-install-stuck.html
if that fails, uninstall using the correct uninstaller from https://helpx.adobe.com/creative-cloud/help/uninstall-creative-cloud-desktop-app.html#sa_src=web-messaging and then reinstall using*
if that fails, do a clean cc install carefully following each applicable step:
uninstall every cc app including preferences per https://helpx.adobe.com/creative-cloud/help/uninstall-remove-app.html
then uninstall the cc desktop app, again using the correct uninstaller per https://helpx.adobe.com/creative-cloud/help/uninstall-creative-cloud-desktop-app.html#sa_src=web-messaging
clean your computer of cc files per http://www.adobe.com/support/contact/cscleanertool.html
check for, and if available, update your os
if windows is your os, repair all ms visual c++ versions that can be repaired (use google if you don't know how to do this)
if windows is your os update your ms visual c++, if it can be updated (use google if you don't know how to do this)
restart your computer (don't skip this)
reinstall the cc desktop app using the "alternative download links" at the bottom of the page at https://helpx.adobe.com/download-install/kb/creative-cloud-desktop-app-download.html
use the desktop app to install your cc programs/trials
NOTE: win 11 users that have trouble with the latest win 10 installer often have success with the older win 10 installer.
Thanks for the extensive guide! I'll try this after hours, i guess re-installing really was inevitable...
