Aug 7, 2019 1:11 AM UTC
Same Problem as Adobe Digital Editions does not work... help!!!. Still no suggestions for fixing
I downloaded the newest adobe digital editions. I was using an older one that stopped working. Now I get an error of check activation. When I try to deactivate this edition I get the error Can't deactivate try again in some time. Nothing is working. Any help would be greatly appreciated.
    Nanaky
    Aug 7, 2019 9:28 AM UTC
    Windows:
        Close all applications.
        Press WINDOWS + R.
        In the Open text box, type regedit and then press Enter. The Registry Editor opens.
        In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
        Remove the Adept Folder.
        In the Confirm Key Delete dialog, click OK.
        Close the Registry Editor.
        Open Adobe Digital Editions and reauthorize..
    Macintosh:
        quit Adobe Digital Editions.
        Navigate to /Users/Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
        If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
