Adobe CS6 Design and Web Premium does not work [on M1 Mac running Big Sur]
I have just got a new Macbook Air and im tryting to get Adobe CS6 Design and Web Premium on to it. It worked on my old Macbook Pro. Does anyone know why it will not work on a Macbook Air 2020 with M1 chip? I have attached screenshots showing the issue.
All applications in CS6 are 32-bit. MacOS from Catalina onwards only run 64-bit applications. I'm using CS6 for my website work its having awesome features.
LinSims
You're out of luck. All the applications in CS6 are 32-bits. MacOSes from Catalina onward only run 64-bit applications.
