Estamos tendo alguns problemas, tente novamente mais tarde. Se o problema persistir, entre em contato com o Suporte ao cliente. "We have some problems, try again to late. If the problem insist, call the suport". Whay???
  • August 13, 2014
  • 827 views
Correct answer Jeffrey_A_Wright
Lacruz0609 are you trying to download and install After Effects CC 2015?  If so then please see Download and install Adobe Creative Cloud apps for details on how to install After Effects through the Adobe Creative Cloud desktop application.
Jeffrey_A_Wright
Lacruz0609 which Adobe software or service is your inquiry in reference too?
Adobe After Effects cc
Jeffrey_A_Wright
Jeffrey_A_WrightCorrect answer
